DC breakers
ws9876ws9876 Posts: 327Solar Expert ✭✭✭
a search on the web for DC din rail breakers always brings up Midnite Solar units for 22 bucks. Is anyone else making DC breakers anywhere in the US that are cheaper..??
  • littleharbor2littleharbor2 Posts: 963Solar Expert ✭✭✭✭
    Midnite Solar breakers are competitively priced.
     You can also look up Square D QUO breakers they have Din rail mounting and are rated for up to 48 volt systems. That being said They aren't recommended for higher voltage PV strings.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
  • PhotowhitPhotowhit Posts: 4,606Solar Expert ✭✭✭✭
    edited July 9 #3
    Did you check our sponsors site? They run $11 and change for new Midnite Din rail breakers, up to 90 amps I think (use to be 63). Here's a link to a 15 amp breaker,most popular for combiner boxes. Northern Arizona Wind and Sun has some of the best prices for Midnite equipment you will find anywhere!
    https://www.solar-electric.com/midnite-solar-mnepv-15-amps-circuit-breaker.html
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • mcgivormcgivor Posts: 1,899Solar Expert ✭✭✭✭
    The above link was for an AC breaker here are DC offerings https://www.solar-electric.com/catalogsearch/result/?q=dc+circuit+breaker+
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
    Thanks, I corrected it. Good catch!
