So is what I am envisioning doable?
Don't really need to cross post... It just breaks up replies and discussions between multiple locations. Best to keep it all in one place.
We are all volunteers here so it may take a 1/2 day or 1 day to get a reply. Especially if complex or a bit off the beaten path.
When designing a solar power system, details matter.
What loads (amp*hours @ xx volts or Watt*Hours per day)
Where and when (nearest major city, summer/winter/etc.)
etc...
A couple of small LED lights (0.1 to 1 watt), and a small AM radio (some will run for days on 2x AA batteries at moderate volume). So, for a small system, a modest size battery + small solar panel can do OK. LEDs will use about 1/10th the power as incandescent... And last much longer (10,000 to 50,000 hours typical for LED).
Problems do include--What happens if you have a week of bad weather... Most rechargeable battery chemistries do very badly when taken to "dead". Will you have something to limit discharging.
Solar power is "fairly expensive"... Having lights only on at night cuts usage by 1/2.
Other options include cycling lights (on/off at random or multiple times at night to look lived in). I like to suggest outside motion detector lamps... Instead of a light showing everything that is worth stealing--All is dark until the light comes on--Attracts attention (if there is nobody around--Probably not any useful attention).
Burglar alarms, motion capture Internet cameras, etc.
If somebody really wants to steal something--They will. Years ago somebody/group stole an entire cabin plus in-well water pump... Right down to the foundation.
BB. said: .. Right down to the foundation.
> I am going to put a converter on the battery and have it power up a small radio so it will run all the time, thus keeping the house sounding lived inBetter to locate a radio that will run directly off 12V That saves the losses of running an inverter to create AC that goes to a wall wart to convert to DC for the radio.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Keep loads very minimal, you might do okay, we don't know where this is and I'd make a couple changes. The car battery is a poor option, it's not designed for deep cycling, but if you keep the loads very minimal you may be okay. I'd dump the "converter" inverter if you want house current - A/C, just run 12 volt DC. The inverter would likely be your largest single load by it's self.
I'd use a "regulator" a charge controller in our lingo. with a night time load function to turn on some very small 12 volt LED lights. If you want to be crafty you can hang these from long strings and they may move slightly during the night. Something tiny like a 2 watt LED, I use a 4 watt to read at night. so 2 watt isn't real dim and if it's pointed at a window the light is very directional.
https://www.12vmonster.com/collections/12v-24v-led-lamps-and-light-bulbs/products/dc-12-volt-2-watt-mr16-spot-light-bulb-for-track-recessed-lighting-system-cob-led
Then use a USB small sandisk mp3 player/radio They will play for 15+ hours on their 400mah 3.7 volt battery and will play while charging and find some good efficient speakers.
I would run a direct 12 volt line and use a 12 volt to usb adapter of some type. Either a car adapter or a usb solar converter.
You can turn the gain up on the player. It will play about the volume of speech. I have one playing now through an old pair of Radio Shack speakers now. Look like these.
You could go to a slightly higher powered speakers, but if you hunt you can find speakers that will project enough to be pretty loud. I found some 4" speakers that worked quite nicely, but were ugly and tossed them on may last move. Small battery based speakers that run for hours off a lithium battery should work nicely. drawing less than 2 watts.
This should keep your entire load less than 5 watts per hour, during the evening and less than 3 watts during the day. Run the usb adapter off one set of wires directly off the battery and the light off the switched load connection;
Here's a controller that will control your lighting;
https://www.solar-electric.com/sunsolligcon.html
Might even run the whole thing off a 20 amp power bank and 20 watt solar panel and a system like I describe here but it would be a close thing using USB lights it's likely doable.
http://forum.solar-electric.com/discussion/353371/looking-for-opinions-about-these-2-5-volt-usb-solar-regulators-circuits#latest
There are lots of inexpensive solar/led lights available which incorporate a small, easy to place and streathy solar panel.
If your in a location with a harbor freight you could do the whole set up for just over $220 (with sales/coupons all the time) including the battery, lights, charge controller and panels and cables. Lighting is DC and connects directly to the charge controller and the CC also has a built in USB port.
The only problem with Harbor Freight is you'll need to replace the panels as often as the batteries. Your money would be better spent elsewhere.
What's the good alternative to Harbor Freight then, Littleharbor2? I definitely want to avoid that mistake if it's as you say.
Pretty much anything. Without knowing your daily load requirements this isn't an answerable question. At one time, when solar panels were expensive, Harbor freight kits were attractive. Solar panels have gotten much cheaper while the price of the H F kits have pretty much stayed the same. Unfortunately their thin film panels are so poorly made they tend to only last a couple years before failing. Not positive on the panels but typical H F warranties are 90 days, period. Your best bet is to stay away from thin film panels. Poly or monocrystalline panels for the most part should last 20+ years if not damaged. There are tons of inexpensive charge controllers that can meet the needs of someone with a minimal system. Anything above a small non critical system I recommend going with the brand name controllers like Morningstar, Midnite Solar, Outback, or Victron, among others.
The thieves literally dismantled the cabin/floor/plumbing and left the bare foundation behind. This was many years (decade?) ago in the California hills... However, others seem to have similar ideas:BB. said: .. Right down to the foundation.-Bill
Say what??
http://abc13.com/i-need-to-report-a-stolen-house-couple-wants-their-home-back/3034896/"Nothing. Nothing that I wanted to see. I didn't see the house," said Harrison. "All I saw were blocks and pipes sticking out. The whole house gone. Everything except the blocks."Hmm... Follow up story... The property was recently purchased and the company that built/installed the cabin reposesed it (original property owner failed to make payments):
http://abc13.com/3044585/ABC13 spoke with Sergeant Larry Shiver with the Madison County Sheriff's Department. He confirmed the structure was repossessed by a company out of Temple, Texas.-Bill
Shiver said he is now working to speak with the man who sold the Harrisons the property. Shiver said it appears the building wasn't paid off by the previous owner.
"I've never had a house reported stolen in my career yet. This was a little bit unusual but when I went out and looked at the scene, I could tell it was a professional job," Sergeant Shiver said. "It was part of the deal but the problem was it wasn't specified in the writing. Yes, we feel sorry for them. That's why we're looking to find the house. They had belongings in the house. Plus, they put time and effort into the house."Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
- 626 Discussion Forums/Café
