Solar Edge Optimizers & Home Runs
climb_on
Registered Users Posts: 14 ✭✭
Just starting the install of my first system for my new house. As I understand it, Solar Edge optimizers restrict output from the module to 1v and a few hundred mA, until activated by the inverter and the grid. Does this eliminate the need to wait to plug in the home runs last? Seems like it you could just go ahead and connect them along with everything else in this kind of system. Is that right? I'm running 2 strings of 17 modules.
9.8kW Array, (34) 290w Heliene Modules, SE10000a SolarEdge Inverter. 8/12 pitch steel roof. NABCEP PVA. Minnesota.
WHat are you calling a home run, the DC wires or the AC wiresCamden County, NJ, USA
19 SW285 panels
SE5000 inverter
grid tied -
The DC conductors coming from each string to the inverter.9.8kW Array, (34) 290w Heliene Modules, SE10000a SolarEdge Inverter. 8/12 pitch steel roof. NABCEP PVA. Minnesota.
climb_on said:The DC conductors coming from each string to the inverter.Camden County, NJ, USA
19 SW285 panels
SE5000 inverter
grid tied -
Thanks Dennis!9.8kW Array, (34) 290w Heliene Modules, SE10000a SolarEdge Inverter. 8/12 pitch steel roof. NABCEP PVA. Minnesota.
