Charging rate
gav
gav Registered Users Posts: 10 ✭✭
hi I have 2 volt tubular gel batteries and where wondering what these batteries holding rate is ( volts) and when charging what max volts should it be? This is 12 volt series. I have a picture of them in wind generator help.i have a 50 amp protects charger should I put it to power supply when charging daily which holds at 13.8 and only charge with stage charging once a week or month.?
    I am going to close this "discussion" (aka thread). And move your question to your other discussion. Usually makes things less confusing to keep your system questions together. -Bill
