8v golf cart batteries,howe to wire for 24V?
patdufo
patdufo Registered Users Posts: 7 ✭✭
I have 6 8v golf cart batteries and I am trying to make 24v?series conection that I used with 4 6v batteries doent work because I am left over with 2 positive and 1 negative?every way that I tried ended up 16v?
  • MrM1
    MrM1 Registered Users Posts: 487 ✭✭✭✭
    edited June 2018 #2
    Maybe I'm not seein what you're sayin. Wouldn't that configure as 3S/2P
  • mcgivor
    edited June 2018 #3
    There is no way with 6 × 6V batteries to achieve a series parallel configuration for 24V, it's either use 4 in series ~ 200Ah, or 8 in series parallel, 4 in each string × 2 for~400Ah.
    Edit. Disregard abuse statement for 8 volt  batteries.
    8 (eight) volt batteries... Yes, 3x in series by 2x parallel strings (6 batteries total).
    Should work fine. Make sure they are fully charged (or each battery at a similar level a charge--You don't want a discharged battery in series with a charged battery--If you "equalize" the battery bank (over charge at ~30-32 volts), you are pushing excessive charging current through the full battery to get charging current to the discharged battery.
  • mcgivor
    Missed the 8 volt, need to buy some stronger reading glasses.
