BMS can only handle 20 batteries!
yrtrncyrtrnc Posts: 36Solar Expert ✭✭
Hi guys
I'm in a pickle.
I want to connect 32 100 Ah 12.8v victron lifepo4 smart batteries in a 51.2v 800ah config. Victron says its a no no as their bms can only handle 20 PCs. Something to do with the communication wires getting overloaded.
So my question is, is there a safe way around this? Maybe another brand bms? Or perhaps no bms at all?
System consists of 3 10000kva quattros in 3 phase. 20kw array with 5 victron 150/70 mppt chargers. Color control gx and a bmv 702 battery monitor. Victron BMS.
  • BB.BB. Posts: 27,776Super Moderators admin
    I will bump your post so that it can gather a few more views... But I really do not have anything useful to comment on.
    Perhaps you can talk to any large companies doing business in your region (Turkey?) directly besides Victron.
    You might find somebody that is engineering larger systems and would be interested in a "partner" to design and test at a live installation.
    Just out of curiosity, can you tell us a bit about your use? It seems to be a lot of power (30 kW of inverter, and a Li Ion battery bank with very high surge capacity) with a relatively small (kWH of battery bank) capacity system. Is this some sort of UPS (uninterruptible power supply) installation that just needs to keep power up for 15-30 munites until a backup genset takes over?
  • karrakkarrak Posts: 304Solar Expert ✭✭✭✭
    Maybe you should talk to someone else at Victron.
    "The BTVs of several batteries can be daisy chained. Up to ten batteries can be paralleled and up to four batteries can be series connected (BTVs are simply daisy-chained) so that a 48V battery bank of up to 3000Ah can be assembled. Please see our LiFePO4
    battery documentation for details."
    If they still insist that the BMS will only handle 20 batteries which contradicts their documentation you could ask them to swap the 100Ah batteries for 300Ah batteries.
    For safety reasons I wouldn't run a Lithium battery without a BMS.
    Simon
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 4p8s (24V), 4kW Latronics Inverter, 1160W of Solar Panels, homemade MPPT controller
    Homemade BMS https://github.com/simat/BatteryMonitor
