EU2000 Honda generator troubleshooting
124»
  • RedFrogRedFrog Posts: 2Registered Users
    This happens without any load!
  • EstragonEstragon Posts: 2,840Registered Users ✭✭✭✭✭
    Make sure the eco mode is off when starting - that can cause problems sometimes.
    Failing that, it might be worth having a look inside to see if there are any loose wires, maybe a short ahead of the circuit breaker?
  • mike95490mike95490 Posts: 7,902Solar Expert ✭✭✭✭
    Try using the generator in plain mode, not eco mode ?    What is the load you are trying to power ?
  • Dave AngeliniDave Angelini Posts: 4,019Solar Expert ✭✭✭✭
    Probably the oil level is too low?
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
  • BB.BB. Posts: 27,897Super Moderators, Administrators admin
    I think I remember that somebody had an oil sensor fail too...
  • westbranchwestbranch Posts: 5,087Solar Expert ✭✭✭✭
    edited June 14 #98
    My sense is also that it is related to the ECO mode. Do you turn to  ECO OFF  for  a minute or more before shutting the machine OFF?....  HONDA recommends it in the manual...It helps to 'flush' out the fuel channels
  • cow_ranchercow_rancher Posts: 104Solar Expert ✭✭✭
    Oil sensors do fail, I had a combination 4KW Gen and Lincoln Welder that I trouble shot for many months, even replaced the carburetor, turned out to be the oil sensor, it had plenty of oil, and in doing searches it turns out that is a common failure for that engine (B&S).
    Rancher
  • DanS26DanS26 Posts: 235Solar Expert ✭✭✭
    DanS26 said:
    I wonder how many thousands of these Japanese designed engines are in the landfills right now because of these hidden fuel filters.
    I don't blame the engineering involved with these small Japanese designed engines......I blame the ethanol mandate.
    DO NOT USE gasoline with ethanol added in whatever amount in your small engines.
    If your engine cannot maintain proper RPM or surges then it could cause the problems your seeing.
    18.2kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro System monitoring with PVOutput.org
124»
