Looking for opinions about these 2 - 5 volt usb solar regulators circuits...
PhotowhitPhotowhit Posts: 4,707Solar Expert ✭✭✭✭
So I've done a basic 5 volt voltage regulator and heat sink for a small usb charger off of a 6 volt nominal panel. it's simple and works flawlessly but I haven't used it much...
I recently saw a couple different voltage regulator circuits on eBay and figured I'd pick them both up and play with them.
Wonder if anyone can point out glaring superiority of one over the other as I have a bunch of solar shingles recently pulled that are 60 watt 6 volt nominal.
Regulator 1
Regulator 2
Both come in small plastic housing, Obviously one has caps and one doesn't...
I was thinking about making some small solar battery bank chargers, and maybe group them with an inexpensive 10,000mAh power bank,
These $10 units appear to be legit;
Auto Drive Power Bank 10000mah
https://www.walmart.com/ip/Auto-Drive-Power-Bank-10000mah/838282049
A usb Fan and light. I think I might convert a couple small 5" O2cool fans, or maybe pop for some better Opolar 8" fans. And a long USB extension power cord, which I might have to make with heavy enough wire so that they can charge a phone inside and run a fan while charging the bank. This begs another question, can These handle having so much available power (7 amps). One of them says 2 amps input, I figured they would take what they needed?
Also would running 2 of these at the same time off of 1 panel be a problem?
Making a thoughtful gift for my family and friends in Hurricane prone North Florida.
Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • VicVic Posts: 2,907Solar Expert ✭✭✭✭
    Hi ..whit,
    Regulator 1,  also has caps,  they are just some Surface Mount types  --  C1 - C8,  on the legend.
    Reg 1,  might be a bit better,   only for the use of those caps,  verses the Radial Lead type,  used in Reg 2 ...   this is based on NO real info.
    Nice project,   good luck,    Vic
    Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH [email protected], 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes.  25 KVA Polyphase Kubota diesel,  Honda Eu6500isa,  Eu3000is-es, Eu2000,  Eu1000 gensets.  Thanks Wind-Sun for this great Forum.
  • Dave AngeliniDave Angelini Posts: 4,021Solar Expert ✭✭✭✭
    I would look very carefully at the battery type of Li-ion and make sure you do not overcurrent it.
    For a gift to family I would only use LFP for safest operation. They also can be damaged from charging too fast.
    Good Luck!
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
  • PhotowhitPhotowhit Posts: 4,707Solar Expert ✭✭✭✭
    Good Luck!
    The battery is the 'power bank' that is linked. It has a built in charging regulator to be charged off a USB.
    Trying to keep this very simple. Mom doesn't even like to use a computer any more.
  • pdhpdh Posts: 23Registered Users ✭✭
    I was thinking the opposite. The radial-lead caps in Regulator 2 are almost certainly higher capacitance than the surface-mount caps in #1, so #2 is likely to emit smoother output voltage (having larger capacitors to buffer the load).
    What would be the reason for preferring the SM caps in #1? (Smaller size or longer life maybe?)
  • BB.BB. Posts: 27,905Super Moderators, Administrators admin
    As always, it is more complex regarding power supply design. There is power supply switch frequency--Generally, higher frequency switching can use smaller capacitors--And inductance of (for example) larger electrolytic leaded capacitors work fine at lower frequencies. And smaller/tantalum/ceramic/etc. surface mounted caps have virtually no leads, and have very low inductance... Which is much better for higher frequency filtering (conductors "block" high frequency current, capacitors "pass" high frequency current).
    More or less, these "can" type aluminum electrolytic capacitors are good for "audio frequency" use (the following spec. is based on 120 Hz base frequency):
    Also note that generic aluminum electrolytic caps have a relatively short design life--The above is 2,000 hours (note there are ~8,000 hours in a year). Long life caps may be rated upwards of 50,000 hours (as I recall).
    Electrolytic Capacitors, in general, are one of the classes of components that have shorter life times/greater failure rates.
    I cannot make out the chip part numbers to figure out the operating frequency. The smaller caps/devices are probably to set the chip's operating parameters.
    I guess that the metal cans are conductors... That they appear to be both the same part (part number), I would guess that both circuits are operating at similar switching frequencies (in engineering, roughly factor of 2x is "roughly" the same. Factor of 10x difference is "night vs day" difference).
    For a long term application--I would start with Regulator #1 -- No electrolytic capacitors. Should have a longer life and withstand heat better.
