60vdc minimum rated 1adc rated glass fuse
Dave Angelini
Solar Expert Posts: 6,746 ✭✭✭✭✭✭
I use to be able to find a Bussman FRN - R 1 amp fuse. It is not made anymore, I found searching.
I could use a PV 600vdc fuse but they are physically bigger than I want.
There is a
https://www.amazon.com/COOPER-BUSSMANN-GMT-1A-INDICATING-ACTING/dp/B00LQP0ZOO/ref=sr_1_fkmr0_3?ie=UTF8&qid=1528048058&sr=8-3-fkmr0&keywords=Bussmann+BK/GMT-1A+Fast-Acting+Fuse;+1+Amp,+125+Volt+AC/60+Volt+DC
Anyone have a line on a typical glass/ceramic type 1 adc fuse rated for 60vdc? Thx!
There is a
Thanks Photowit! Weird that my search did not find it...
A friend also said to look at the Bussman type ABC which is a ceramic case in a standard fuseholded."we go where power lines don't" Sierra Nevada mountain area
Why glass? Common 3AB (like the 3AG glass tube fuses, but with a ceramic body) are rated to 250 VDC. But, if you really want glass - Littlefuse 224 series (2AG) are rated 125 VDC in the smaller sizes.
Read the post again...."we go where power lines don't" Sierra Nevada mountain area
Dave,
The FRN type fuse that you useD to be able to buy, is a Dual-Element fuse (not glass cased), and is designed to be used in circuits, where a large degree of overload protection in needed.
This should be the Data Sheet for that style of fuse:
https://cdn.allfuses.com/media/documents/Bussmann FRN-R (0.1 - 60A.pdfThe fuse that is linked in your first post, really has nothing in common with the FRN style fuses.
It would seen, that if some engineer specified an FRN style fuse, with its dual elements, substituting a fast-acting fuse could result in nuisance fuse-blowing.
All, IMO, Vic
Thanks Vic. I appreciate it as it is a 3 hour ride up into the mountains to change the fuse:(
I ordered the type ABC which seems to be easy to get and meet my number one requirement of not going there and having a DC rating.
Many people assume that 250 volt ratings are DC ratings, which we know is not quite true
Dave Angelini said:Read the post again....
- 626 Discussion Forums/Café
