advice on inverter/charger
wast
Registered Users Posts: 41 ✭✭
any recommendation on a 1000 or 1500 watt pure sine wave 24 volt inverter charger for a reasonable price..
In that size range, you may want to consider separate inverter and charger.
Samlex inverters seem to be well regarded on the forum. Charger would depends on your needs. I went with a pair of relative inexpensive Iotas on my 12v system as I charge that bank almost entirely with solar and only rarely for bulk charging with generator. Other applications may need 3-stage, power factor corrected, etc., charging.Off-grid.
It would seem there are very few to no pure sine wave inverter chargers below 2000W, only modified sine wave.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I just use 2 BD smart 10a car chargers. Only need them a few times in Dec Jan . My battery bank is 7 years old.
ThomOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
anyone familiar with eliminator> they make a 1000 watt pure sine wave inverter
Eliminator is a brand sold by Canadian Tire, if I'm not mistaken, usually 12V and not an inverter charger for 24V, is this the reference?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:Eliminator is a brand sold by Canadian Tire, if I'm not mistaken, usually 12V and not an inverter charger for 24V, is this the reference?
yea u are correct only 12 volt... and not a charger.. may go the inverter and separate charger route.. -
Our host has some smaller 24 VDC input AC PSW inverters:-Bill
- 626 Discussion Forums/Café
