wiring from panels to charge controller to batteries
wast
wast Registered Users Posts: 41 ✭✭
what is correct way to wire 2 panels in series and to controller and on to batteries..do I need breakers in between somewhere
  • Estragon
    Simple answer is yes.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,046 ✭✭✭✭✭
    edited May 2018 #3
    Definitely need a fuse at the battery rated for the wire size you're using. As far as breakers you need nothing for a single string of panels. That being said you might want to add a small breaker box for convenience when doing system maintenance. Bad pic sorry. Old stuff.
