Mini Split update for Offgrid
12346»
  • mike95490mike95490 Posts: 7,611Solar Expert ✭✭✭✭
    Dave Angelini said:....We had a thunderstorm on friday that dropped such huge hail, dirt clods were being thrown up. Pretty wild to drive thru also.
    How do PV panels hold up to that ?  Marble sized ?  ping pong ball size?
  • XRingerXRinger Posts: 515Solar Expert ✭✭✭
    When I see those softball sized hailstones, I look outside at my little PV investment and think.. Those would never survive golf-ball hail..
    http://abcnews.go.com/US/video/texas-hit-massive-hail-38327607
    It was just that you guys got so hammered with one after another I  thought you might have bit the big one. I am glad that it worked out.
    Cheers!
    The only people we saw get hammered, were hit by falling trees. We've been driving around looking at the before & after of these storms and can't believe all the tree damage. Never seen anything like this.
    This one happened about an hour after we had driven right by that big tree..
    http://www.wcvb.com/article/woman-injured-by-falling-tree-in-woburn/19061248
  • Dave AngeliniDave Angelini Posts: 3,631Solar Expert ✭✭✭✭
    Yes trees ! The big equalizer. We have nasty hail here but when you have a 25 year product warranty for glass and everything else,
     it was tested in development and made it once again. :)
    My neighbors call and say when you come down the hill, bring the big saw. I am not sure mine is big enough for you east coasters ;)
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
    A few years ago, one of my panels was hit by a falling limb. It was a small limb, but it left a tiny ding in the glass.
    Nothing that you would notice from 3 feet away.. The panel worked fine for a couple more years,
    until I made the mistake of cleaning with a garden hose. I noticed a small dot on the panel and sprayed it with the hose..
    A small amount of water got under the glass. An hour later, that little spot was burning under the glass. The burn was ~ 1/4" wide..
    I disconnected the panel, and the burning stopped. A nice 200W Canadian Solar, is now a fire hazard!
    My point: If you have hail on your PV panels, you need to put on a magnifier rig and inspect every square inch of your array..
    You might have some micro damage that escapes notice..
    We gaze onto their glass and just are amazed. Often this happens at happy hour :)
    My point is, really good solar panels, I mean relay good, come with a 25 year product warranty. If you bought them from Panasonic, or Sunpower or LG, all you need is a receipt and you get a new panel or  a check. Because I am one of the few who insist my clients have at least one tracked array they use the best panels. This is because the best also have much better power to size ratio. This  helps them fit on a tracker. In the old days Sanyo was the king but they sold to Panasonic, as you know Rich.
    The product warranty is far different than the power warranty.
    I thought you guys were not suppose to get sun until May :)
    E-mail offgri[email protected]
    It's nice and sunny right at this second..  It will be mild for a while. But winter is coming back on Monday. :(
    https://www.tropicaltidbits.com/analysis/models/?model=gfs&region=us&pkg=T2m&runtime=2018032812&fh=84
    edited May 3 #159
    I buyed 2 mini split systems with 9000 BTU indoor units, works very well.
    spam link deleted... -Bill B.
    AirCon 9000 Btu 22 SEER 220V Mini-Split Heat Pump Air Conditioner. $749.99 ex. tax
    Midea 9000 Btu 24.4 SEER 110v Super Inverter Mini Split Heat Pump AC. $899.99 ex. tax
    That is amazing delivery time! You were just asking 2 days ago and you already have them, not to mention installed and working. It is almost impossible to believe :D
  • littleharbor2littleharbor2 Posts: 877Solar Expert ✭✭✭✭
    You may have "buyed" yourself a timeout for advertising.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
12346»
