mixing strings of panels??
Wbuffetjr1Wbuffetjr1 Posts: 78Registered Users ✭✭
I HAD 3 strings of Solar Word 345 watt panels.  One string is demolished.  I can longer buy the 345 watt panels , but can buy the Solar World 350s.  If I have 2 strings of 345s and 1 string of 350s will that be a problem? Classic 200 charge controller.
Thanks for the input
  • HorseflyHorsefly Posts: 310Registered Users ✭✭✭✭
    Shouldn't be a problem at all. Looks like it is actually the identical panel, but has tested out to a slightly higher efficiency. Vmp on a string of two would be 0.6V higher, which is less than 1%. Go for it.
    Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 4 x Vmax XTR12-155 12V, 155AH batteries in a 2x2 24V 310AH bank.
  • EstragonEstragon Posts: 2,840Registered Users ✭✭✭✭✭
    Even identical panels can vary a bit (eg part of an array gets a cooling breeze). If the frame still physically fits, it should be fine.
  • Wbuffetjr1Wbuffetjr1 Posts: 78Registered Users ✭✭
    great! Thanks fellas!
  • mike95490mike95490 Posts: 7,904Solar Expert ✭✭✭✭
    Tough luck with that tree fault detector circuit.  Hope the fix is not too much of a pain.
