mixing strings of panels??
Wbuffetjr1
Wbuffetjr1 Registered Users Posts: 92 ✭✭
I HAD 3 strings of Solar Word 345 watt panels.  One string is demolished.  I can longer buy the 345 watt panels , but can buy the Solar World 350s.  If I have 2 strings of 345s and 1 string of 350s will that be a problem? Classic 200 charge controller.
Thanks for the input
  • Horsefly
    Horsefly Registered Users Posts: 470 ✭✭✭✭
    Shouldn't be a problem at all. Looks like it is actually the identical panel, but has tested out to a slightly higher efficiency. Vmp on a string of two would be 0.6V higher, which is less than 1%. Go for it.
  • Estragon
    Even identical panels can vary a bit (eg part of an array gets a cooling breeze). If the frame still physically fits, it should be fine.
  • Wbuffetjr1
    great! Thanks fellas!
    Tough luck with that tree fault detector circuit.  Hope the fix is not too much of a pain.
