Hello everyone. Made a quick video on Epever MPPT Charge Controller. While going through it I realized that Gel batteries do not have to be equalized. Is this true or should I worry that Epever does not have an equalize for Gel Batteries..? Hope someone can help.
Thanks.
Lead Acid EQ is typically ~16 volts or so.
"EQ" for GEL and AGM is typically normal absorb voltage (14.2 or 14.4 volts) and held for 2-6 hours or so--That is the "sealed battery" EQ (very mild "over charging").
Used to be thought that NEVER EQ sealed batteries.... Now, some folks believe 2-6 hours of "EQ" (at nominal charging voltage) every 6 months is better.
-Bill "not a battery engineer" B.
