Amp Meter giving different reading from CC
Seanadirondacks
Seanadirondacks Registered Users Posts: 20 ✭✭
On the positive incoming line from solar array im getting an amp reading of 12+ on the CC its reading around 20. Its a new amp meter and im new to using them. Thanks
  • mcgivor
    edited April 2018 #2
    The second image shows an ammeter set on the AC scale, what's needed is a DC clamp on ammeter, AC amps are not the same as DC amps,, the reading will always be inaccurate, you need an ammeter capable of reading DC amps.
    The best advantage of a clamp on DC ampmeter, is you will never be tempted to use it in the AMPS mode, when you measure the volts on your battery.  Doing that pretty much will ruin several peoples day.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,044 ✭✭✭✭✭
    Been there, done that. Bought new DVM.
     Fortunately the meter died a fast, flame free death.
