#4 wire splicer?
SeanadirondacksSeanadirondacks Posts: 20Registered Users ✭✭
Would these aluminum splicers be good for #4 wire with max 60 amps? Thanks.
  • VicVic Posts: 2,897Solar Expert ✭✭✭✭
    Hi Sean,
    The pic or Link did not make ..
    What you are looking for on these types of devices is a marking that says:  Cu-Al,   or Al.   There may well be a specified range of wire gauges that the device will accept.
    Always use an anti-ox type compound,  after burnishing the Al conductors,   like NoAlOx (r).
    FWIW,   Vic
    Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH [email protected], 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes.  25 KVA Polyphase Kubota diesel,  Honda Eu6500isa,  Eu3000is-es, Eu2000,  Eu1000 gensets.  Thanks Wind-Sun for this great Forum.
  • SeanadirondacksSeanadirondacks Posts: 20Registered Users ✭✭
    > @Vic said:
    > Hi Sean,
    > FWIW,   Vic
    Link is up now. Looks like ive got the right ones. Thanks for the info and advice!
    Sean,   YES,   those look fine.   Thanks for the pic.   Vic
