1470w Poly or 1100w Mono Panels
gjlsangjlsan Posts: 4Registered Users
Is there a real difference between 6 x 245w Poly Hanwha ($899.95) and 4 x 275w Mono Recom Panther ($908.32)?
Charging Time, Power production, etc.
Hanwha 245w Poly - 14.8% eff, Vmp 30.3V, Imp 8.08A, -0.45%/°C Pmax Temp
Recom Panther 275w Mono - 16.6% eff, Vmp 32.12V, Imp 8.45A, -0.39%/°C Pmax Temp
  • BB.BB. Posts: 27,883Super Moderators, Administrators admin
    Poly panels are slightly larger than same rated mono panels (watts per square foot/meter).
    Poly panels tend to be cheaper $/Watt than mono panels.
    Personally, if either panel meets your needs, go with the cheaper panels (assuming similar quality and support).
    Bill
  • EstragonEstragon Posts: 2,838Registered Users ✭✭✭✭✭
    IMHO, not much difference in most applications. Maybe in space constained locations (higher efficiency may mean being able to get more watts in available space), or extreme climates where the temp coefficient might be a factor.
    By the way, can you tell us more about your system?
    Where will the system be installed, what voltage and amp hour battery Bank, what type of solar charge controller? Etc.
    What are the loads you want to run, etc.
    Bill
  • gjlsangjlsan Posts: 4Registered Users
    Hi,
    I'm in PR and still without power since hurracaine strike. I'm looking for a substitute for my 2k generator.
    I'm looking for a 24v system, 2k-4k inverter, 3.92kwh bank (4x6v/245ah) with a 60a mppt controller to run house lighting, tv, fan and small refrigerator (and all the small gadgets chargers).
  • fratermusfratermus Posts: 22Registered Users ✭✭
    I think those are 60cell panels, which might not reliably able to hold Vabs on a 24v system unless at least some are in series.
    Another thing to think about is mono's higher Vmp disadvantages PWM further.  I assume OP wouldn't be using PWM but if s/he did the poly would generate more power than mono at Vbatt.
    2017 Promaster 159" DIY camper
    570W mono / 220AH GC
  • myocardiamyocardia Posts: 118Solar Expert ✭✭✭
    edited March 28 #7
    Hi,
    You will want to reconsider buying a 2-4,000 watt inverter. A 1,000 watt inverter will easily run everything you mentioned, and will use use less than half the battery power per day than a 4,000 watt will use. It is what we call "tare loss".  A 4,000 watt inverter will use close to as much battery power per day merely being switched on with zero things plugged into it as the things you're considering powering will use in that same 24 hour period. Buy a good quality 1,000 watt inverter, and use that battery power to keep your food cold and your fans running, instead of wasting it as heat, powering an inverter that is WAY, WAY too large for your battery bank.
    Concerning the solar panels, always pick mono over poly, except when it costs you power to do so. If you can buy 1,500 watts of mono panels for close to the same price as 1,500 watts of poly panels, get the mono. Since you will be able to buy 50% more panels with roughly the same money, and get 33% more power from them, the poly panels are the only way that makes sense.
    edit: This is the inverter you should buy. Yes, it costs twice per watt what the junk on Amazon costs, but it will last for many, many thousands of hours, and won't drain your batteries in an hour, like the 2-4,000 watt Amazon specials will:
    https://www.solar-electric.com/sa1wa24vosiw.html
    DoD= depth of discharge= amount removed from that battery   SoC= state of charge= amount remaining in that battery
    So, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoC
    A/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use)
