Absorb time
Cgarner
Registered Users Posts: 2 ✭
I have a system that is less than one year old off grid. My battery shuts off only after one hour of use. I have 9 panels, 285 wats, outback flexpower 120 Volt. 4 outback 12v batteries sealed. it is set to 1 hr absorb time. If I change my absorb time to 2 hours do you think it will help my issue
What is the Manufacturers recommended time for ABSORB? Is your charger using a BTS or RTS ? and YES if you are in the northern part of the world, the longer ABSORB time should help long term but you may already have damaged your batteries with only 1 Hr of ABSORB
.It is better if you post all the charging parameters rather than one part at a time as there may be other factors involved, rather than guessing...
It's also helpful to start a single post/thread for a single issue. Multiple threads tend to confuse things.Off-grid.
I will close this thread so the discussion can continue in the other thread... Carry on over here:
http://forum.solar-electric.com/discussion/353136/customer#latest
Unfortunately, with this forum software, I cannot merge threads/discussions.
