Need some basic advise on panel urgently
WandaFletcher
Registered Users Posts: 5 ✭
Hey guys, I am not total noob to solar but don't have enough knowledge to decide on anything. So here is what I need to know asap; I plan to switch on 100% solar for my guest house. My requirement is approx 300-350 units a month. Considering this, I think 3 KW should be sufficient to meet the requirement. I have many things to understand; First Point is, how it matters if I go for 30 Panels of 100Watt or 12 Panel of 250 Watt? Does it make any difference in performance.
2nd point is: some people are advising me to buy from local guy, but they have given much higher quote than compared with walmart/amazon etc. For example, the local guy has quoted around $15K, while it cost me significantly less if I buy online
AIMS (250WX12) https://www.walmart.com/ip/AIMS-Power-PV250POLY-250W-Solar-Panel-Pack-of-6/354293383 ($7500+Shipping)
Aleko (250WX12) http://www.sears.com/aleko-gdt-spu250w12v-ap-aleko-spu250w12v-monocrystalline-modules/p-SPM14914267515 $5600+Shipping)
HQST (100WX30) https://magesolar.com/best-solar-panel/ ($4900+Free Shipping)
Mighty Max (100WX30) https://www.amazon.com/100-Watts-100W-Solar-Panel/dp/B01HHDC6NQ ($3300+Free Shipping)
So I plan to buy online and use the local installer only for installation and support. Another advantage is the local guy is also going to do paperwork for 30% tax credit which I am not sure if it will be easy to do on my own if I buy online.
and last important point is; should i look only for branded panel or I should go with affordable one (I personally would prefer to go with low cost)
Please suggest asap (I have less than 2 days to make a decision). Thanks a ton in advance
Does your guest house currently have grid power ?Anything you take OFF-GRID will cost you at least 5x as much as grid powerPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
WandaFletcher said:Please suggest asap (I have less than 2 days to make a decision). Thanks a ton in advance
You need to know what type of system you are setting up. A grid tied system (no batteries, electric fed back into the grid) a hybrid system (back feeding the grid with backup batteries in case the grid goes down) or an off grid system just solar array and batteries often with a generator for backup power.
I would stay away from Sears and Walmart, and look for solar specific store. neither of those even said basic info, like if the panels are UL listed.WandaFletcher said:I think 3 KW should be sufficient to meet the requirement.WandaFletcher said:My requirement is approx 300-350 units a month.WandaFletcher said:First Point is, how it matters if I go for 30 Panels of 100Watt or 12 Panel of 250 Watt? Does it make any difference in performance.
Generally the ~250W 60 cell panels are the cheapest per watt, due to supply and demand, because they're used for grid tied systems, watch out for shipping costs on larger panels. By 100% solar are you proposing off grid? because that's a loosing battle financially if grid is available and contrary to popular belief it's not as green as it painted.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Also, guests can be idiots left to their own devices. I'd include idiot-proofing capability in the overall system.Off-grid.
mike95490 said:Does your guest house currently have grid power ?mcgivor said:Generally the ~250W 60 cell panels are the cheapest per watt, due to supply and demand, because they're used for grid tied systems, watch out for shipping costs on larger panels. By 100% solar are you proposing off grid? because that's a loosing battle financially if grid is available and contrary to popular belief it's not as green as it painted.
If by Hybrid you mean Panels on the Guest House and you will NOT have batteries you should be calling that GRID TIED.
Hybrid means a combo of Grid Tied and also having batteries for times when the grid goes down, ie
Hurricane or snow/ice storm.
These systems use altogether different equipment like Sunny Island by SMA.. .. https://www.sma-america.com/products/overview.html
once you add batteries to a PV solar system, it will consume $ and never produce a profit or break-even.
westbranch said:If by Hybrid you mean Panels on the Guest House and you will NOT have batteries you should be calling that GRID TIED.Hybrid means a combo of Grid Tied and also having batteries for times when the grid goes down, ie
Hurricane or snow/ice storm.mike95490 said:once you add batteries to a PV solar system, it will consume $ and never produce a profit or break-even.
Now i got the basics to rework on my plan from fresh. Thanks a lot
First you need an accurate, as possible, inventory of the things you want to cover with the GT array, and compare that to the largest array you will allowed to have GRID TIED... depending on where you at the regulations may restrict the max array size...
Generally, if your site is not plagued with frequent blackouts and only have an occasional outage, a backup generator & Transfer Switch (auto or manual) is the most cost efficient. Fuel it with propane or city gas, and you eliminate the stale gas problem. And you save $8,000 in battery replacement costs every 5-8 years.
mike95490 said:Generally, if your site is not plagued with frequent blackouts and only have an occasional outage, a backup generator & Transfer Switch (auto or manual) is the most cost efficient. Fuel it with propane or city gas, and you eliminate the stale gas problem. And you save $8,000 in battery replacement costs every 5-8 years.
What Mike said510 watt pv, TS-MPPT 60, Exeltech XP1100, XP600 & XP250 @ 24V, 4x Trojan 105RE, Trimetric 2030, Yamaha EF2400i gen.
