kid charger
ws9876ws9876 Posts: 318Solar Expert ✭✭✭
Can I use my KID to do an equalize charge on a generic lead acid car battery...??? I mean separate from any solar set up..
just the KID and the car battery...??
  • VicVic Posts: 2,879Solar Expert ✭✭✭✭
    Hi ws..,
    Believe  that you are referring to the MidNite Solar KID MPPT Charge Controller.
    The KID will need a source of power,   ideally,  a/some PVs.
    Some car batteries may not like an EQ  ...   have never EQed a Low or No Maintenance car battery.  Many/most car batteries are Lead Calcium.
    Why do you believe that that battery needs an EQ?
    Vic
    Off Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH [email protected], 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes.  25 KVA Polyphase Kubota diesel,  Honda Eu6500isa,  Eu3000is-es, Eu2000,  Eu1000 gensets.  Thanks Wind-Sun for this great Forum.
  • EstragonEstragon Posts: 2,331Registered Users ✭✭✭✭
    My understanding is the kid has to be used with pv.
  • BB.BB. Posts: 27,446Super Moderators admin
    And, most solar charge controllers... Connect the DC Battery bus to the charge controller first, then connect the solar panels second (switching breakers, etc.).
    Connecting the solar panels first can, on some charge controllers, confuse them (auto-select the wrong battery bus voltage, not boot correctly, etc.).
    edited March 3 #5
    Hi Estragon,
    It is generally true that it is best to use most MPPT CCs with PV input sources.
    Fairly early in the MidNite KID's evolution,  it was suggested by MN Engineering,   that the KID's Legacy O&P Mode be used with stiff external power sources.
    It is now suggested in the KID Manual version 1856,   that the U-SET Voc%  Input be used for Constant Voltage external sources.
    From the 1856 manual,  here:
    http://www.midnitesolar.com/pdfs/kid_manual_rev_1856.pdf
    It does state on page 36,   to use the U-SET Voc% Input function:
       "   ...   U-SET VOC%
    This is a fully manual mode based on a percentage of VOC. The Kid will sweep based on the user set
    time in minutes and then park at a user set % of the VOC the Kid found on that sweep. This mode is
    useful for testing or constant voltage sources. Press Save then press menu back when done. Modes
    will revert to OFF if the up or down arrows are pressed before exiting.   ...  "
    Portions possibly Copyright 2017 MidNite  Solar.
    We do still use an external SMPS with the KID here.  Some safety guidelines when using the KID  are,  Use an external power supply with an Shout Circuit max current, less than 30 A,  a power supply output voltage,  not exceeding two times the nominal battery voltage,   etc.   Just my personal opinions.
    FWIW,  if the OP  has any need of any of the above.     Vic
    @Vic - interesting, I hadn't realized Kids had that degree of tweakability.
