Don't pop Water Miser caps when it is below freezing.
softdown
Solar Expert Posts: 3,812 ✭✭✭✭
The plastic hinge may break.
Which reminds me of a recent subject of great interest. Why do people choose to live with long, severe winters? Why do areas with long, severe winters generally offer better statistics on factors such as crime, income, IQ, and education?
Another thing happened that I do not recall. A little bit of battery acid got thrown into my face. If the eyes had been hit, the discomfort would have likely been significant. Surmising that, in milder weather, I used my fingers instead of more aggressively popping the caps with a large screwdriver.
Water Miser caps would seem to enjoy varying opinions of their effectiveness. As for me, I'm pretty sure that they lower water consumption enough to warrant their usage.
Cold weather crime stats:
Midas: Canadian Car Chase: http://youtu.be/0id9fUYb95AOff-grid.
How do the caps work in the cold? Do they freeze up with ice, or "snow" the water back to the electrolyte?Off-grid.
Estragon said:How do the caps work in the cold? Do they freeze up with ice, or "snow" the water back to the electrolyte?
I should proceed this afternoon since the battery plates are starting to show just a smidge.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Estragon said:Cold weather crime stats:
Though I personally fear that Canadians have crossed a certain line in the sand with the election of Prime Minister Peoplekind Cuck. I think Castro is his biological father based on a few things. Notably the almost identical appearance and the documented relationship between his mother and Castro. Castro's other son grew up with constant comparisons to his Canadian "brother". But that is completely off topic.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Don't vote - it only encourages them ;-)Off-grid.
Maybe warm the caps up a bit before opening them?Off-grid.
Estragon said:Maybe warm the caps up a bit before opening them?
Everything was pretty routine after the temperature reached 40Freedom. It should be noted that these caps do best with a very strong push to ensure that they are properly closed. They will click close with a normal push, then click again with a stronger push. At least mine do that.
Now I wonder what will happen tonight when the battery descends to ~0F. The freshly installed water will likely freeze and expand and.......? It was ~2pm when I added a cup of water to each ~140 lb cell.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
When cold, plastic gets much stiffer and brittle.
mike95490 said:When cold, plastic gets much stiffer and brittle.
It did not get below ~20F last night. The newly added water did not freeze.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I just spent a long weekend at my "summer cottage". Temperatures this year went to about -10F at night. Solar panels were working fine. But as to the batteries, I didn't even look at them. Considering only 50 Ah were accumulated over 3 months of winter charging, I figured they were fine and never checked the electrolyte.Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
