Desperately Seeking Normally Closed Latching Contactor (but not that desperate)
124»
  • LostinSpaceLostinSpace Registered Users Posts: 45 ✭✭
    edited January 30 #92
    So, just to wrap up, I go the cells top balanced successfully. The array is all buttoned up with the cell covers and the spaghetti wiring is as cleaned up as possible. System is up and running.
    Rick, your point about the cells staying in balance once the top balance is completed is well taken. As much as I would prefer to think that the balancers I purchased are a worthwhile investment, and in spite of how elated my battery vendor was to find these devices, and although the balancer maker has years worth of testimonies, and although the balancers may help at the bottom of the range if one is looking to squeeze every last bit of charge out of the array (depending on load and how quickly the devices can balance those cells with a bit less capacity, I would find it hard to justify the expenditure when I expand the array.
    For anyone reading through this meandering thread I would summarize my take on the balancers as follows:
    1) The balancers seem to balance voltage, but they do not balance state of charge (SOC). At least not over the 2-3 day period I left them on the pack after inserting the replacement cell.
    2) The vendors website gives the impression the balancers will balance SOC, although it does not specifically state that. And it certainly does not qualify that the balancers only balance voltage.
    3) The balancers do not prevent over charging or over draining of a cell. A BMS of some sort is still required (even if it is simply tapping into the celllog output as karrak suggested.
    This project has been partially designed to be a learning experience so I have no regrets. In fact there was one other failed experiment I will mention. I chose to use Unistrut as a lower cost way to ground mount the solar panels. I think that goal was achieved (I ran the numbers on several engineered ground mount solutions and the unistrut always came out more competitive). However I pushed it bit to see if I could pull of an adjustable mount that could increase the angle of the panels in winter and decrease the angle in the summer.
    Toward that end I used "Telestrut" which is simply a strut inside a strut. I deployed the telestrut on the angled struts the panels mount to (although there are other approaches). The basic idea works, BUT it turned out to be a major PITA to make the adjustments, as I designed the system anyway).AND, telestrut is insanely expensive. It diluted all cost savings the unistrut approach had achieved, making the mount as costly or more costly than the engineered mounting systems. But again, not a headache as this was an experiment. The mount is one of four that will be built (6 panels per mount), and now I know what works and doesn't work.
    Qty 24 Sharp 153W poly panels, Midnite MNPV6 combiner, Magnum MS-4448-PAE inverter with RC50 remote, Magnum MMP Mini panel, Midnite Classic 150 charge controller, Qty 32 LiFePO4 72AH cells in 2 string 48V array. BMS.
    Oh, and I did measure the cellogs with a Fluke.... 4MV difference.
    One other note for anyone considering Unistrut (not telestrut). DON'T use the unistrut solar end clamps, mid-clamps, or angle brackets. I tried them, but found third party solutions better engineered and less expensive. For example the Unistrut mid-clamps did not have as much meat to overlap onto the panel as say, the ProSolar clamps.
    edited February 15 #95
    UPDATE: At this stage of the project I am now finding it difficult to successfully perform a top balance before placing the array back online. I once again tried to get the third party balancers to balance the cells, but even after leaving the balancers on for 4-5 days, all the balancers did was balance cell voltage, not SOC. In trying to get the array up 3.4 volts or higher -out of the flat part of the curve- a few cells will bang up against 3.65v, while many cells are still at, say, 3.38x -- and thus pack charging must be discontinued. I am now rating the balancers as "less than worthless".
    I tried placing a DC lamp on individual cells to discharge the full cells, but finding that is taking foooorever. So I have taken Karrak's que and purchased a hobby charger. Simon, you had expressed curiosity about the capacity of the damaged cells. Now that I have a cell charger I'll let you know. I was going to buy a Turnigy Reaktor 300W, but found a bruising review of the latest version (claiming product has gone downhill) from someone who seems to know what they are talking about. I ended up purchasing two different units for comparison; an HTRC B6 Mini V2 ($25 + $16 for power supply), and an iMax B6AC V2 ($57).
    So now I am essentially starting over. I don't think I ever payed close enough attention to top balancing the cells when first purchased. Now I'm going to try and do it right. My intention is to cycle each of the 32 cells, charge them fully, and measure capacity and internal resistance. Will post results comparing the good to the overcharged cells when done.
    Cheers
  • jonrjonr Solar Expert Posts: 889 ✭✭✭✭
    edited February 15 #96
    I haven't followed this thread, but isn't the idea of a balancer (bypass or active) to allow exactly this?   Ie, you can safely continue charging because no more current will be applied to the cells that are at 3.65V
    I expect that if you hold all the cells at 3.65V long enough (which implies a very low current), they will all be pretty close in terms of SOC.
    I agree that once one cell reaches max voltage, charging should only continue at an amp rate that the balancer can handle.  Fail to do this and a cell would see excessive voltage.
  • karrakkarrak Solar Expert Posts: 247 ✭✭✭✭
    Thanks for the update.
    I am not sure that your balancers are useless. It looks like your battery is badly out of balance and it will take a while for the balancers to balance it.
    The way to stop the situation where you are having some cells at 3.38V and some going over 3.65V is to reduce the SCC (charge controller) bulk voltage and float voltage to around 54.1V (3.38*16) and wait for the balancers to balance all the cells to within 0.05V. When this has occurred increase the bulk and float voltage by 0.2V and wait for the balancers to do their work. Keep slowly increasing the bulk and float voltage until you reach 57.6V(3.6*16). This can be done over several days. I hope you have your Cellog 8 connected to your SCC to stop it charging if any cell voltage goes higher than 3.65V.
    It is a shame that Hobbyking is no longer selling the version of the Turnigy 300W that I bought. My charger is functionally the same as the Junsi iCharger 206b which is still available. There is a 10A version, the 106b and a 30A version, the 306A. The two units you bought will be just about useless for discharging the cells as the maximum discharge current is ~1.5A-2.0A at 3.2V.
    Simon
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 4p8s (24V), 4kW Latronics Inverter, 1160W of Solar Panels, homemade MPPT controller
    Homemade BMS https://github.com/simat/BatteryMonitor
  • cow_ranchercow_rancher Solar Expert Posts: 71 ✭✭✭
    How about listing your sources of supply for your Unistrut 3rd party parts?
    Is telestrut just not Unistrut  with sizes that telescope into one another?
    Rancher
    Well, not exactly. The balancers I have do not stop current from flowing into a cell once max voltage is reached. They are not that type. But, they are daisy chained to each other and are supposed to equalize voltage among the cells over time. So far though I have found that although they equalize voltage -over time- they don't seem to be equalizing SOC. See my reply to Karrak also.
    Simon
    I gave the balancers 4 days to balance the pack with no charge coming in. Maybe I should have waited longer, I don't know.
    I had first tried reducing SCC on this latest foray to get the cells balanced as you are suggesting. I can't recall exactly but I think I did start at around 54.1. Then when any cell went full I stopped and let the balancers do their work (did not wait anything near 4 days though). I was able to slowly increase the voltage, and did this several times. But finally it reached a point where some cells would immediately hit 3.65 while others lagged in the 3.3x range. Again, resting the pack with the balancers still not equalize the charge.
    I now watch the meter through all these exercises and NEVER let a cell go over 3.65. ;>
    I am strongly disposed toward charging and testing each cell individually at this point. So if the chargers I bought don't cut it I will swap them for a Junsi unit.
    By the way, when measuring internal resistance of a cell, is that performed at full charge? Documentation is not clear on that.
    As always, thank you.
    jim
    cow_rancher said: How about listing your sources of supply for your Unistrut 3rd party parts?
    Rancher
    There is photo of the balancers and the vendor listed earlier in this thread. But let me say that in spite of my earlier comment that the balancers are less than worthless, I don't want to trash the vendor at this point, because I am one person, on a first time system, and you don't want to draw conclusions from that. I have spoken with the vendor and the maker in China - very cooperative, and swearing that thousands of balancers sold with few issues. So I could just be being idiotic on this. As I alluded to, knowing now what I have learned from Karrak and others, I may not have have been fastidious enough at the very beginning in getting the cells top balanced properly. That is why I am starting over from scratch and charging each cell individually, as well as testing it. Maybe down the road the balancers will prove effective if I get everything setup properly from the getgo. ;>
    Yes, the telestrut is just a 1/8" oversized piece of unistrut. And for that they charge you about 10X over unistrut. Gotta love it.
    edited February 15 #102
    There are various games a manufacturer can play with specs for a charge shuffling (aka active) balancer.   For example, say it's rated at 6A.  But 6A at what differential between two cells (charge moves faster with a higher V differential in capacitor type designs).  Continuously or intermittent?  And of course if the low cell is several hops away from the high cell, then the effective rate is much lower.     Once one cell reaches max voltage, charging needs to be limited to this unknown effective rate (not the rated amp rate).  Do that and no cell will over-voltage up to the point where all cells are at max voltage.  A cell at 3.65V being charged at 5A with charge being shuffled away at an actual 6A *will* decrease in voltage.
    If a charge shuffling balancer doesn't have cells voltage balanced after no load or charging for 4 days, then I think it is defective.  It would only take a failure of one unit.
    Someone should put these balancers on the bench and get some real specs.
    I'd be happy to mail you one or two if you want to volunteer. This whole project at this point is just an expensive hobby/experiment. I have grid power.
    Are you letting the battery charge to say 54.1V then terminating the charge or leaving it charging at 54.1V?
    If you terminate the charge the individual cell voltages will all drop and converge so that the balancers will do nothing.
    Below is a graph showing how the individual cell voltages diverge while the battery is being charged and come back together when the charging stops. This battery doesn't have any automatic cell balancing.
    It is really easy to connect the cellog 8 up to your Midnite.
    This is the best way to get your system up and running. How were you planning to do the capacity test and balance the battery using the Junsi unit?
    I wouldn't use the Junsi unit to measure the internal resistance. The apparent resistance of the battery is affected by how much current you are drawing/supplying, the temperature and the SOC. A better test is to take a reading of the battery or cell voltages and current when it is in use with a small load of around C/20 and then apply a large load > C/2 and take the voltage and current readings. The resistance is
    Rbat=(Vc/2-Vc/20)/(Ic/2-Ic/20)
    If you want to see how much this charges over time you should make the measurements under the same conditions with the same current draw.
    Simon
    edited February 17 #105
    Wow. Another very helpful graph. Nice to see that that sort of temporary deviation is to be expected.
    Thanx for holding my feet to the fire on this one. Today I programmed my cellogs to close the output relay if any cell exceeds 3.60, or if pack voltage exceeds 28.5v (half of 57v). The trick will be to get my Midnite Classic charge controller to stop charging on the proper external input. The Classic has two Aux ports, but only one of the two can be programmed for INPUT, and I'm already using it for a WizzBang Jr.; a device to track power usage and SOC. So I am going to take this up with the Midnite people. Ha. This topic almost wraps back to the original reason I made the post
    First, slight change of plans. The Junsi + power supply is ~$200. I have other places for that cash to go for the moment. So I am keeping the two lesser units for now (30-day return window), foregoing capacity testing at this point, and yesterday I individually charged 16 of the 32 cells to 3.60. Today I put the array back together, and this afternoon will put a moderate load on (standup freezer) and see what happens. No balancers. I did measure the cell voltages after sitting overnight and they are running from 3.487-3.564 (77mv dif).
    I was actually going to ask you how your charger does capacity testing. Does it have a dedicated feature that will cycle the battery and report an AH number? If not it occurred to me that you could simply time how long it takes each cell to go from, say, 3.45 to 2.8, and compare the results across all cells to at least get an idea about relative capacity. Or you could discharge all cells at a fixed current rate and calculate AH?
    Yeah, for giggles I used the internal resistance function the iMAx unit (clearly the better of the two I bought), and readings were all over the map, even though temp was somewhat uniform and I tested just after completion of charge to 3.60.
  • Raj174Raj174 Solar Expert Posts: 516 ✭✭✭✭
    @LostinSpace
    Even though all the cells are 3.6 volts, they are not balanced. But I suspect that you know that. If I were to use the bank that way, I would use the balance boards because as the cell voltages diverge the boards will protect the cells with slightly lower capacity from getting over charged. Then the bank can be charged until the individual cells reach 3.6 volts.
    If the cells were balanced at 3.55 to 3.6 volts then no balance boards needed and absorb could be set to 55.2. Have you considered charging all the cells in parallel?
    Rick
    12 x 300W Renogy PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 195AH HI Power LiFePO4 no BMS, 4000W gen.
124»
