What percentage of "solar batteries" expire due to a bad cell?
I suspect the number may be quite high. I also suspect the phenomenon could be greatly reduced by the manufacture of a high quality battery.
Why do I feel this way you may ask. It is because every 8D that is waiting for the scrap yard was perfectly serviceable except for one bad cell, two bad cells in one case. One battery was pushed until it developed two bad cells. FWIW....that particular battery created a 2am power loss in the middle of July in an alpine desert. Bad cells poison the entire array. Two bad cells would seem to destroy the array output. Kind of like a short circuit in a way.
Currently still using three 8Ds that were manufactured in 2011. One is pretty good, the other two are fair to pretty good. Their only other value is scrap lead so I figure they help shoulder the burden for the better 8D batteries. Plus this is an experiment that I like to conduct. My childhood hero was Edison before I learned about Tesla.
Which leads to another subject for conjecture. At what point is it economic to pull a battery? Opinions will vary widely depending on whether one buys or sells batteries I bet.
0
Oh, yes I have experienced this and have learned a valuable lesson.
At 20, I would be prepared to undergo a lot of pretty unpleasant treatment to address a health issue if I was otherwise healthy. At 80, not so much. Similarly, I'd replace a dud cell/battery in an otherwise healthy young bank, but in an older bank I'd be making end-of-life arrangements.
Sulfation is a bit like a slow growing cancer - it'll kill you eventually, assuming something else doesn't get you first, and will make you pretty sick in the meantime. Batteries can also die of something more like a heart attack, when enough plate has shed to the bottom to short the cell. Baby a bank with low voltage absorb etc will likely mean a lingering demise of the first type, vs more aggressive charging regimes resulting in the second.
7 years is getting a bit long of tooth. If I was one of those 8Ds, I'd be getting my affairs in order.
I still have four 8D's of mediocre quality left over from my last bank using eight 8D's of mediocre quality. Remnants of a "beginners mistake". Thinking I may wait until a bad cell develops before yanking. Unless, of course, SG drops below fair.
Built in 2011....yes. But not placed into service for a few years. Stored in cool to cold conditions. Which reminds me, the bottom battery bank is cooler than the top bank was. The bottom batteries have fared much better. I think ~75% of my replacements went to the top bank. Wish I had kept detailed records of that.
A couple feet may represent a significant temperature difference when the lower bank is virtually sitting on a cool floor.
