About multiple uses of VFD drive of solar pump
kcbibek310kcbibek310 Posts: 21Registered Users ✭✭
I am thinking of using VFD of a solar pump for other purposes when the pump is not working. I am thinking of using it in a thresher. Is this possible to do so with the same pump controller/inverter? If possible then how can we do so and what is the perfect controller for such purposes?
  • mike95490mike95490 Posts: 7,786Solar Expert ✭✭✭✭
    VFD's are made for specific motors.  If your thresher has the same motor as the pump (doubtful) it would work.
  • peakbaggerpeakbagger Posts: 341Solar Expert ✭✭✭
    Long ago on an industrial drive application I needed to do a proof of concept system where I wanted to drive two different horsepower motors from the same drive. This was an industrial VF drive with a removable HIM module. The drive had no problem driving a much smaller motor but the settings had to be reprogramed for the smaller motor. The solution was get a spare HIM module and program it for the smaller motor. When the motors got swapped, we would swap the HIM.
