Perfomance data from LiFePO4 (LFP) Battery
13»
  • northernernortherner Posts: 492Solar Expert ✭✭✭✭✭✭
    westbranch wrote: »
    Concur about vagueness... what does this mean?
    Does it need to be depleted to 60% to store or that it will go down to 60% after 5 years???
    1% . onht = 12% / yr = 60% dod after 5 years...
    I think it means that if the cell is stored at a 60% state of charge it will only be good to sit on a shelf for 5 years. Likely due to self discharge as you mention. Not sure if it has anything to do with degradation of the cell over time, but I have also read that LFP is best put to use, and not left sitting unused?
  • Blackcherry04Blackcherry04 Posts: 2,486Solar Expert ✭✭✭
    Not to pretend I know anything about Balqon or Winston Battery, I know what I read or was told. Balqon said they have a container shipped once every 3 weeks from China. They fill it with customer orders or stock, it takes 21 days to deliver in LA port providing there is no snag. So you could say delivery is 6-8 weeks or more at best depending on how the order falls and if there is room in the container. Then they have to go to their shop and shipped to you ( 1-2 weeks ) .
    They went through a few rough years financially. Supposedly Winston Chang owner of Winston Battery owns portion of Balqon he bought as a bailout to keep a distributorship going here ( USA ). Take for what it's worth, internet BS maybe.
    I guess you'v noticed a sharp price increase, that 700 ahr went from $700 to $840. Like everything in business, if sales pick up , things will get better, maybe cheaper. The supply chain is a problem for them.
  • PNjunctionPNjunction Posts: 762Solar Expert ✭✭✭
    Balqon isn't the only player in town. GBS and CALB have stock in the U.S. Canada, and elsewhere from various distributors, like Elitepowersolutions etc. It is much easier to get local nationwide stock than it was 5-7 years ago.
  • karrakkarrak Posts: 278Solar Expert ✭✭✭✭
    Back again after an uneventful year with my and my friend's off-grid power supplies.  I have not noticed any change in the battery performance during the year.
    During the year I have added several new features to my battery monitor:
    Access to realtime battery data via the internet using a web browser
    Logging power as well as Ah
    Have added another shunt to measure power coming from my solar controller
    Added DOD figure which takes into account battery coulomb inefficiency, hoping DOD figure will now be accurate to within 1%
    In summary
    The maximum Battery Charge rate was 44 amps (~0.12C)
    The maximum Battery Discharge rate was 225.7 amps (~0.63C)
    The minimum SOC was ~18% actually this was more likely 13% as I only ever charge the battery to around 95%
    The average SOC of the battery was 76% which is the same as 2014
    Minimum battery voltage was 24.5 volts
    Maximum battery voltage was 29.5 volts
    From the charge and discharge figures the battery coulomb/current efficiency is ~99.4%. This figure sounds amazing, but does match up with a number of technical papers I have read on the subject.
    Overall power efficiency for the last six months of the year is ~95%
    Raw Data for 2015
    timestamp = '20160101000002 '
    maxvoltages = [3.687, 3.634, 3.693, 3.685, 3.658, 3.773, 3.796, 3.809, 29.51]
    minnoload = [3.17, 3.154, 3.171, 3.162, 3.172, 3.176, 3.175, 3.177, 25.36]
    minvoltages = [3.071, 3.045, 3.064, 3.048, 3.041, 3.09, 3.054, 3.078, 24.49]
    deltav = [0.001, 1.462, 1.462]
    amps = [-44.0, 225.7, -45.4]
    ah = [-27.08, 83.887275, 296.45, 509235, -27040.43, 26791.92, -17609.84]
    dod = [-13.44, 87.522555, 296.45, 11]
    power = [-352.419131, 335.345255, -431.953613, 392.385055]
    KEY
    'maxvoltages' is the maximum voltage measured over the year of each cell and the pack as a whole
    'minnoload' is the minimum voltage measured over the year of each cell and the pack as a whole with a load of less than 10A
    'minvoltages' is the minimum voltage measured over the year for each cell and the pack as a whole
    'deltav' is the difference in voltage between the highest and lowest cell in mV measured over the year, the first reading is the lowest difference, the second in the maximum difference with a load less than 10A, the third is the maximum difference
    'amps' the first two figures are the maximum battery charge and maximum discharge current measured over the year, the third figure is the maximum current from my solar controller.
    'ah' is the raw DOD of the battery in Ah measured over the year, my pack has a nominal rating of 360Ah, the first figure is the lowest DOD, with 0 being 'full', the second figure if the average DOD, the third figure if the maximum DOD 360 should be empty, the forth figure is the number of samples the average is taken over, the fifth figure total charge going into the battery in ah, the sixth figure is the total charge drawn from the battery in ah.
    'dod" are the same as the 'ah' figures but compensated for battery coulomb/current efficiency. The forth figure is the maximum number of day between when the DOD counter was reset
    'power' are the total power figures for the system, they are only for the last five-six months of the year. The first figure is the power going into the battery, the second is the power coming out of the battery, the third is power from the solar panels.
    There is a minute between samples.
    Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
    32x90Ah Winston cells 4p8s (24V), 4kW Latronics Inverter, 1160W of Solar Panels, homemade MPPT controller
    Homemade BMS https://github.com/simat/BatteryMonitor
    Another uneventful year with both my friends and my battery. Finally got his battery out the hot tin shed and into a cupboard in his cool straw bale house. It doesn't look like the time in the shed has had much impact on his battery which surprises me.
    If I have read the date codes on the battery correctly my battery is four years old and has been in service for around 3 years and nine months. If we assume that each day is a cycle then it has been cycled  around 1,300 times. Again I have not noticed any change in the performance of the battery.
    After much research I have come to the conclusion that keeping an LFP battery at ~99%SOC and floating it at this SOC will not have a large effect on the lifespan so have instituted this charging regime. This has increased the average battery SOC to 81% up from 76% and has meant we have been running low on stored energy on fewer occasions.
    In summary
    The maximum Battery Charge rate was 47.8 amps (~0.13C)
    The maximum Battery Discharge rate was 226.2 amps (~0.63C)
    The minimum SOC was ~10%
    The average SOC of the battery was 81%
    Minimum battery voltage was 24.5 volts which is the same as last year
    From the charge and discharge figures the battery coulomb/current efficiency was ~99.6%.
    Overall power efficiency was ~96%
    Raw data for 2016
    ('timestamp', "'20170101000004 '")
    ('maxvoltages', '[3.675, 3.736, 3.686, 3.712, 9.881, 3.691, 3.72, 3.707, 29.56]')
    ('maxnocharge', '[3.469, 3.52, 3.476, 3.511, 3.47, 3.468, 3.534, 3.498, 27.91]')
    ('minnoload', '[3.138, 3.104, 3.215, 3.119, 3.144, 3.137, 3.222, 3.139, 25.77]')
    ('minvoltages', '[3.044, 3.01, 3.064, 3.019, 3.027, 3.055, 3.052, 3.049, 24.51]')
    ('deltav', '[0.002, 13.296, 13.296]')
    ('amps', '[-47.8, 226.2, -47.7]')
    ('ah', '[-34.68, 66.611916, 314.91, 485477, -24543.84, 24447.19, -34265.2]')
    ('dod', '[-37.43, 66.813219, 324.48, 16]')
    ('power', '[-653.178156, 626.080888, -907.617511, 880.520243]')
    KEY
    ''maxnocharge' is the maximum voltage when the charge current has dropped down to C/50 (7.2A)
    'ah' is the raw DOD of the battery in Ah measured over the year, my pack has a nominal rating of 360Ah, the first figure is the lowest DOD, with 0 being 'full', the second figure if the average DOD, the third figure if the maximum DOD 360 should be empty, the forth figure is the number of samples the average is taken over, the fifth figure total charge going into the battery in ah, the sixth figure is the total charge drawn from the battery in ah, the seventh is the total Ah from the solar panels.
    'power' are the total power figures for the system. The first figure is the power going into the battery, the second is the power coming out of the battery, the third is power from the solar panels, the forth is the power going to the loads.
    Simon
  • SwanneySwanney Posts: 8Registered Users ✭✭
    Great post Simon (Karrak)
    I run about the same sized setup as you. 300Ah 24v LIFEPO4 (Sinopoly) 8 cells in series and 1400 watts solar 5kw inverter, Cellog 8. Installed 2013 and was a bit of a leap of faith.
    My settings have been the same since installed, approximately the same as yours. Cells 2.95v - 3.45v. Pack 24v to 27.4 volts and I manually top balance every 6 months or so (which is never out much).
    So far so good, haven't noticed any drop in performance over the years.
    The cellog disconnects my inverter if needed via the output alarm and works fine. My battery monitor (voltronics) gets a bit out of wack if I don't reach 100% SOC for a few days, which is frustrating and means I have to rely on voltage monitoring.
    Good reassurance for me to see your settings are similar.
    Andrew
    Yet another year slips by, again no drama.
    Batteries have done ~1,700 cycles now and are nearly 5 years old, half way through my hoped for lifespan.
    The measured 8% minimum SOC is the lowest the whole battery has ever been, from the individual cell voltages it looks like cell 2 has about 1% less capacity that the others. From the average voltage I calculate the SOC to be ~6%-7%.
    Calculated battery impedance/resistance with a load of 157A on the 30th of December to be around ~5mOhms ((26.68V-25.97V)/(157A-16A). This figure hasn't changed since I installed the battery.
    Made some modifications to the monitoring software.
    We have been at home more of the time so the power consumption has gone up a little to ~3.1kWh/day.
    In summary
    The maximum Battery Charge rate was 45.6 amps (~0.13C,~1.2kW)
    The maximum Battery Discharge rate was 245.7 amps (~0.68C,~6.0kW)
    The minimum SOC was ~8%
    The average SOC of the battery was 78%
    Minimum battery voltage was 23.51 volts
    Maximum battery voltage was 28.43 volts
    From the charge and discharge figures the battery coulomb/current efficiency was ~99.7%.
    Overall power efficiency was ~96% same as last year
    Raw data for 2017
    ('timestamp', "'20180101000001 '")
    ('maxvoltages', '[3.52, 3.606, 3.537, 3.605, 3.526, 3.512, 3.547, 3.563, 28.43]')
    ('maxnocharge', '[3.495, 3.552, 3.507, 3.553, 3.499, 3.49, 3.535, 3.541, 28.16]')
    ('minnoload', '[3.018, 2.937, 3.019, 3.032, 3.046, 3.068, 3.096, 3.056, 24.31]')
    ('minvoltages', '[2.928, 2.836, 2.922, 2.926, 2.939, 2.975, 2.994, 2.959, 23.51]')
    ('deltav', '[0.0, 0.313, 0.434]')
    ('ioutmax', '[245.7, 0.7, 235.1]')
    ('kwoutmax', '[5.835, 0.019, 5.977]')
    ('kwhout', '[796.56915, 5.9044, 1140.6176]')
    ('iinmax', '[-45.6, -47.3, -2.1]')
    ('kwinmax', '[-1.24, -1.286, -0.055]')
    ('kwhin', '[−830.13527, -109.16759, -0.11369]')
    ('ah', '[-7.06, 66.616583, 239.44, 523551, −31035.42, 30930.38, −44217.65]')
    ('dod', '[-56.61, 79.938458, 330.81, 18]')
    ('power', '[−823.57124, 790.57637, −1177.6169, 1144.6221]')
    KEY
    Simon
  • Dave AngeliniDave Angelini Posts: 3,776Solar Expert ✭✭✭✭
    Nice job Simon! Very nice work! The drama is always nice when it is low offgrid!
    With the fire danger year round here now, I can't say no drama anymore like the old days.
    With 1 year on the RESU10's I saw a 1% loss from cycling. I have no idea how to calculate the life.  LG said over 20 years.
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
    I forgot, I have been keeping track of how much adjustment I have had to make to keep the battery manually balanced. I have two cells, cells 2 and 4 or I should say block of cells as there are four individual cells paralleled to make a block which have less charge loss than the others. When the cell voltage of these cells gets to around 3.5V which is about 0.05V above the other cells at the end of the absorb phase I will remove some charge from them with a resistor placed across each of the blocks for around 10 minutes which equates to reducing the charge stored in the block by ~0.5Ah. Last year I removed ~1.5Ah of charge from each of these blocks which equates to ~0.4% of SOC.
    Simon
13»
