Homemade lead acid batteries
BjornM
BjornM Registered Users Posts: 8 ✭✭
Has anyone made their own lead acid batteries, and can share some about their result on this? It's a toxic dirty process, but I'm planning to give it a try this year. The reason for this is that I want to find a way to constantly recycle my batteries when they fail, and I have the time and facilities to do it.
I will try the Plante process, where you start with sheets of lead and form them through many cycles of charging/discharging and reversing polarity. The batteries will not get anywhere near the capacity of factory made ones, but most likely they have a much longer life span. Perhaps in the order of a 1/4 capacity and 4 x lifespan. Can describe the manufacturing method here if anyone is interested.
With all the new battery technology coming, I think lead acid will soon be an obsolete technology, so there will be a big surplus of lead that can be found cheaply.
Off grid in a small cottage in western Sweden.
«1
  • tabbycat
    tabbycat Solar Expert Posts: 55 ✭✭✭
    Lead is toxic.
  • mcgivor
    Yes lead is toxic, but with all relevant precautions, the hazards can be reduced to near zero, the closest I've personally come to recycling batteries is replacing plates with manufactured plates, during my apprenticeship, before the molded case battery technology, am I dating myself?
  • oil pan 4
    I have open air smelter old car batteries for lead, it's a very nasty process.
    I don't recommend it.
  • softdown
    softdown Solar Expert Posts: 3,821 ✭✭✭✭
    I thought my battery adventures were interesting.........
    I have thought that making batteries with a lower SG would lower output and increase longevity. Thoughts?
    When lead becomes cheap then battery prices crash and FLA batteries remain competitive. I would think. This is all bound to be good news for solar electric power.
    We are talking about using an EMP on N Korea prior to a military strike. That may boost an increase in interest in a back up power supply. The problem is that EMP's may also take solar power installations.
  • oil pan 4
    edited January 2018 #6
    Ahhh yeah the worst case scenario for high altitude thermo nuclear sourced EMP will generate something like 6 to 7 mega watts per square meter for a few micro seconds. Everything is fried in the effective area. But the good news is the effected EMP over kill zone should only be around the size of roughly north and south Dakota.
    But the power grid coast to coast is going to be fried, even if smaller gadgets that were not connected to the power grid are all unharmed.
  • softdown
    Interesting....national power grid is toasted, I have read that. What about our solar set-ups? Are you saying that a big EMP would take out the electronics in an area the size of the Dakota's?
    I ground my equipment in five places.....not too sure it is realistic to do more. Wrapping stuff in aluminum foil may be prudent but it just feels weird as heck to me.
    I think a foreign power is far more interested in taking out the national grid than BBB/Bill's Bed & Breakfast with AAA service.
  • oil pan 4
    At least the size of the dakotas, and because of earths magnetic field it wont be evenly distributed, directly under the blast may not be severely effected, also the areas  near the north and south may not be too seriously effected, the areas to the east and west of the detonation will feel the full effect. In the 6 to 7 megawatts per square meter induced area not just solar will be fried, every thing, cars, cell phones, calculators, planes, trains, automobiles. The only thing that might still work would be incandescent bulb flash lights.
    Further away east and west smaller gadgets, vehicles, anything not connected to the power grid should be fine. Large off grid solar arrays may still fry, just because of their surface area and the power grid for the same reason.
    for EMP, it's all about the length of the antenna that picks up the pulse.   Long wires = fried gear.  Big PV arrays are going to get zapped. Idle panels in your bunker, may live.  Panels undergound and not connected to anything metalic would live.
  • oil pan 4
    Panels and anything in dark storage should be fine.
    When soviet union did a nuclear test there was a lot more going on then conversion of matter to energy, they tested all kinds of bunkers, 60s electronics, shielding. The US did too but the soviets had more of a bunker obsession.
    What about Farraday cages?  they should offer some negation of effects,  YES?
  • softdown
    No expert at all here though I find the subject a bit fascinating. I thought that was pretty much the idea behind Faraday cages.
    I have thought I would keep stuff protected but found it to be a notorious hassle to worry too much about.
    I have some foam insulation with aluminum foil on front and back. If I placed that overhead of my inverter/CC.....that would help a little bit I would think.
    Guess it may be smart to toss back up laptops into a disconnected microwave. Two laptops started the death spiral just this wee. One blacks out, the other kind of grays out with squiggly lines. Like me, they are getting old.
    A Faraday cage is "ideal" for preventing electro-magnetic energy from getting into the stored products. However, the doors/etc. need to be electrically "connected" too. If you do not connect the door to the rest of the cage, energy can get in through the "slot antenna" of the door and jam.
    Realistically, it depends on the frequency of the EM waves that are from the sun, lightning strike, EMP, whatever source, how far away it is, etc.
    For the most part, solar flares need "antenna" on the order of miles to 10's miles (or longer) plus or minus.
    Here is one discussion:
    http://forum.solar-electric.com/discussion/22934/emp-and-solar-system-protection/p1
    More or less, design your system with good rules--As in for protection against lightning strikes (more likely to happen for most folks, vs the beginnings of nuclear war--I hope and pray).
    If the source of the EMP is close--Then, higher frequency EM waves are possible and could affect something as small as your solar power system. However, if close, then you are looking at xray and gamma ray radiation--And would need hundreds of feet of earth to for the electronics to survive the radiation.
    Of course, your chances of surviving a nearby nuclear strike are not great either.
    If we have a CME (coronal mass ejection) or very large solar flare, more than likely the issues will be your utility power (lots of long wires to act like antenna) and communications cables (telephone, cable tv, etc) bringing that energy to your home. Again, wavelengths much longer than would affect the normal off grid power system for a home.
    The issues with CME, as I understand, is the very high current/voltages that can be generated by the long wires of utility lines--Which can take out some very big and expensive, and long lead time, regional power transformers--It generally takes a few years from order to installation for these babies (in good times). It is supposed to be reasonably "inexpensive" to protect these "national infrastructure" transformers and power systems--But so far, not a lot has been done (by governments or utilities).
    These concerns seem to run in cycles... We had a lot of these types of questions around 2011 (CME/EMP/etc.). I was just going through some of the threads to find some quick answers--And a few of those sites seem to have "expired" in the subsequent years (lack of interest, lack of money?).
    If we have some event (natural or man made) that takes out the electric grid of the US--Things are going to get very difficult now that most of our population is urban (something like 1% of the US population still is connected to farming). If (when?) all of the electrical infrastructure stops working for a few years or decade....
    A steel 55gal drum. with lid and rim clamp makes a pretty good Fariday cage.
  • oil pan 4
    edited January 2018 #15
    Lightning is also an emp. It energizes the atmosphere for a few moments around the strike zone. It can cause damage with out a direct hit.
    Solar flare is typically 0.5v per km. So a real bad one the likes of which we have never seen could be maybe 4 or 5 volts per km.
    I have a few good tests to do to check effectiveness of a home made cage.
    If you can put a cell phone in there and it still has signal, probably not going to do anything. If you can't see inside your protective covering try putting a battery powered radio in there, if it gets signal when sealed, probably not going to do anything.
  • clockmanfran
    clockmanfran Registered Users Posts: 94 ✭✭✭
    Yes I messed about replacing cells in GEL, (fibre glass soaked separators) some 10 years ago. And seriously looked into making my own lead acid.
    The Plante process is probably the best for DIY builders.
    There are several How to books on the Plante process.
    In General polypropylene containers are readily available and can even be made fairly cheaper to your own specifications.
    Polypropylene woven material is also easily obtainable and can be used as socks for each plate and acting as a plate separator, as it was always the comb plate separator that I struggled with in the past.
    Its all about weight, and what is movable safetly. I went with a max of 60Kg, 132lbs, 2v cell, but my amperage was only half that of a commercial produced cell of the same size and weight. But on the other hand I can use/clean/resuse each cell pretty well for ever, and certainly outlast the commercial boys.
    Its just the thought of doing 24 individual cells that can be daunting.
    Everything is possible, just give me Time.
    The OzInverter man. Normandy France.
    3off Hugh P's 3.7m dia wind turbines, (12 years running).  ... 5kW PV on 3 Trackers, (8 years) .... 14kW PV AC coupled using Used/second hand GTI's, on my OzInverter created Grid, and back charging with the AC Coupling and OzInverter to my 48v 1300ah batteries.
  • oil pan 4
    edited January 2018 #17
    Your amps were half of commercial cells?
    That's impressive.
    All the nay sayers who haven't done anything like that before like to claim you will get a small fraction of commercial batteries of the same size.
    Please tell us more.
  • BjornM
    Thanks clockmanfran, interesting.
    I bought Phillip Hurley's book "The battery builder's guide", but found it to be poor. Lots of practical details about casting lead etc in there, but no real science. And it seems like the author didn't have much experience in building batteries, because there are no real plans in there, and no numbers for what to expect.
    And Googling around I've found nothing of real value, except a few simple tests, but no one who really put time and effort into anything.
    Do you have suggestions for better books or sources of information?
    I've found a good source of polypropylene felt, commonly used for ground cover. Will use it as a plate separator.
    But still many questions remain, such as the details of the Plante method (what current, how many times, etc), what thickness of plates is a good compromise, the surface of the plates (how to increase the area), etc.
  • clockmanfran
    oilpan4,
    I did not do any actual data tests, it was just my observations.
    I expected only a 1/3rd but got about 1/2, its the Plante process, the more you add oxide to the plates the better it gets. I wire brushed my appropriate plates.
    I think the reason for better amperage is those polypropylene socks, it means I can get more plates tight in the available space, without using some sort of physical comb separator.
    There are many variables, sock leaching particles, plate wire brushing direction or random, weight of each plate, type of holding for each plate etc etc. So a heck of a lot of experimenting required.
    One day, when I get time, I might do a 'How to Make a Lead Acid Battery' to join my collection of 'How to Do' books.
    Heres my OzInverter book, all my books are real practical books with lots of Photos ..........
     http://www.echorenovate.com/the-ozinverter.php     ..... and ....
     ........ http://www.echorenovate.com/new-book--make-a-6kw-inverter.php
  • clockmanfran
    BjornM
    yes , I have Phillip Hurley's book "The battery builder's guide".
    He actually did that small Plante lead acid battery, so at least he tried. He does give actual amperage output, which is what I used to calculate what I could get, and his figures seem approximately correct.
    So the information in his book is sparse but its there.
    Next time my 48v 1300ah battery bank needs replacing, I will serious do a Plante cell.
    However at present I have found a cost effective solution that suits me.     I am using commercially available 12v 110 amp, SLA, 30kgs/66lbs, so called Ultra Deep Cycle Marine, another term is Golf cart buggy batteries. These I can obtain New at $75 each.   48 batteries at $3600.
    I have had 12, 3 strings, of these on test with my battery bank for the past 6 years, and they have behaved very well, so early this year I replaced all my old GEL's. Got a good deal payback at the scrap/ recycling yard/depot.
    Its getting the weight, amperage, voltage, reliability etc, all at the best Cost effective Solution.
  • BjornM
    Clockmanfran:
    What I would like to have seen in Phillip Hurley's book was at least one building project, with dimensions of all items, and the resulting amp-hours he got from this build, how well it lasted over time, etc. The reason he doesn't present this makes me suspect that none of his own battery experiments were really successful.
    $75 each for a new deep cycle 110 Ah battery, that's a steal. They cost more than twice that around here.
    Do you have any specs on your inverters? THD, efficiency at various loads, idle current, etc.
  • clockmanfran
    edited January 2018 #22
    As you say, Phillip Hurley's details are poor, but its possible to scale from his photos.
    If I recall/remember he is the only guy that I have seen with the DIY Plante Process. But at that size of battery all the time taken etc the output amperage is not good for the investment.
    But at least he did it!
    OzInverter, at idle for the real 6kW, (and I mean it runs all day at 6kW if your batteries can. And takes AC coupling and DC coupling), idle is about 30 to 40 watts.
    It depends on the inductance choke and how you wind the toroid for the Teslas figure. Its a compromise between low Teslas of around 1.00 to a 1.50.    More turns on the toroid elevates, but then copper losses and getting the windings in become a hassel.
    But in general it pretty well shows the commercial guys a clean set of heels. Sorry its an English term of speech, ie, Its better than the commercially manufactured Inverters.
    Its all in the posts, somewhere.
  • Deveak_Kaizen
    Deveak_Kaizen Registered Users Posts: 31 ✭✭
    I have the same book. Did as much research as I could. I have some reclaimed bullet lead I want to try. I think the antimony will slow down the process but should increase cycle life. I did find a company who sold them but its a small one in italy but they do list the plate thickness, capacity and weight. 200 AH cells have about 59 lbs of lead.  So around 3.4 AH per lb of lead. They use a combed ridge shape plate. 1/8 inch deep by the looks of it. Home made I would say 3 Ah per lb of lead would work. Also it is a function of plate thickness. These batteries used a plate thickness of nearly half an inch, .450. So a plate thickness of .225 which is close to a fork truck would be around 6 AH per lb. Not bad. Double the weight of a standard cell but who cares if its stationary?
    My only issue so far is cases. I tried tearing down some 6 volt SAN cases from stationary batteries, the clear kind. I couldn't get them apart without cracking them. To old and brittle and the interior walls are glued tight. New cases would be preferable. Looking into 3d printing now. I have yet to find a US supplier who will sell me any. Most think I am a lawsuit waiting to happen and the others are stuck in set up forever. Very frustrating. Test cell wise I plan on just using half gallon mason jars with plastic lids. Mcmaster carr sells polypropylene felt you can make sock separators out of. The mud hole at the bottom needs to be deep and the plates need a shoulder on the side to rest on. Most plante plates hang, they expand down when charged so they need a bit of room. Kind of like a T shape.
    The bullet lead is basically free. I can get an unlimited amount but I may need to build a bigger melter. Its a lot of work. 6% antimony, 2% tin. It does run the risk of permanently losing capacity. The antimony may slow the forming process so much it might shed material and not replace it. Technically thats a temporary issue, I think a slower (EVEN SLOWER!) process of forming might be necessary. Just charging and discharging. Solar may be a good way of forming it very slowly. Like running a dc freezer after a partial forming and waiting a year or two to check the capacity.
  • clockmanfran
    edited February 2018 #24
    Good to here you are putting some thought into the cell structure.
    It has concerned me regards internally supporting the lead sheets/plates, but at 1/2 inch thick they should be self supporting, ie not stretch under their own eight, if suspended as you say like a T, in polypropylene tanks with the plates not exceeding say, 26 inches in length.
    My original concept was to construct each cell of 10 plates at 26inches long with their socks on, and then have the tanks made up to my specs. Although I will have to visit the tank makers and ask there advice on the thickness of the polypropylene for the use and weight I have in mind.
    I/2 inch thick, 12.2mm, crikey that's a lot, I was thinking of standard rolled 8mm thick lead sheets, as they are commercially obtainable at that size, and then ridge each appropriate side.
    So a fair bit of experimenting required.
    Keep us posted how your project goes, lots of photos so others may learn.
  • BjornM
    Very interesting Deveak, thanks for the info.
    I've also been thinking about the antimony and tin. Maybe they affect battery performance, and if so, if there is some simple way to remove them from the lead. Perhaps though forming of lead sulfate salt that could be separated and then turned back to lead again.
    The plate thicknesses you mention seem like over doing it to me. I was thinking of maybe 1/8", but maybe that is too thin? What Italian company did you find? Would like to read their specs.
    Not easy to find bullet lead here in Sweden. I will try to find a really cheap old broken boat with a lead keel and buy it. Or beg for old used car batteries around the workshops.
    I wonder if the plate separation distance has any effect on the battery performance. I suspect it doesn't, and the only reason it is kept as small as possible is to make the batteries smaller in size. But for an off-grid application, battery size doesn't matter much, so a bigger distance is probably the way to go to prevent shorts, etc.
    Just like you, I'm going to try big mason jars for my initial tests, and maybe for all future batteries if I can find at cheap price. IKEA sells some. Easy to see the inside to keep track of what is happening.
    Might try two really long plates that are rolled up into a cylinder and put into the mason jar. Some old batteries have that configuration, and I wonder if that is easier than using multiple flat plates for each cell.
  • wayneworkman2012
    wayneworkman2012 Registered Users Posts: 15 ✭✭
    edited March 2018 #26
    @BjornM I would recommend making salt water batteries. Salt water batteries have much lower energy density compared to other energy storage solutions, but are dirt cheap to produce and are made of completely non-toxic materials - in fact you can safely eat the materials used in their construction and not be harmed. In addition to those benefits, they are very safe and resilient. You can discharge them very deeply daily, and the materials are not flammable and are safe to touch.
    Here is some information on salt water batteries that I gathered together from duckduckgo.com searches:
    Please reply with how construction goes, I am very interested in this endeavor myself.
  • Deveak_Kaizen
    ah sweden, from what i hear, your going to need some luck. As for lead pure is best. It will consume little water, have high cycle life and low resistance. Should handle a 15% of the 20 hour rate charge fine. You can't separate antimony or tin from lead once its in, not without a very complex process involving gases under pressure. Tin is recommended. It adds some rigidity and cycle life with no drawback. Almost all industrial plante plates use 1-2% tin.
    http://www.primordial.it/en/home-2/
    Here is the italy company. Youtube videos show he started making them in his back yard.
    Antimony I would experiment with, its the number one additive to batteries that add cycle life but may cause problems with the plante process. It may slow down the forming process so much it could take years to form a cell. It may also affect the "regeneration" of the cell where it forms new material from the lead as it sheds the old. Thats the reason why it retains 100% of its capacity its entire life. Keep in mind that would likely be a temporary problem and light cycling would negate that, a heavy cycle may slough off a large section and take some time to replace. Either way it will add cycle life but it will eventually end up in the negative. Causing antimony poisoning of the negative. Increases resistance and makes for a thirsty battery. You might not even be able to reverse the cells during forming because it would speed that up even more. jelly roll works fine for round cells but a square plate would have better surface area.
    Plate separation is important. Larger gaps increase resistance. You can get polypropylene felt and make plate socks out of them, should never short out.
    Wayne, they always tout how cheap saltwater batteries are to make but the prices don't reflect it, neither does the cycle life which is good but nothing a good fork truck battery can't surpass for a fraction of the cost. Typically the salt water batteries I have seen are around 3000 cycles at 50% DoD which is good but not amazing. They also cost as much as lithium batteries. My fork truck cells at home are good for 3250 cycles at 50% and cost 1900 shipped for a 12 volt 1060 AH battery bank.
  • BjornM
    Thanks for the info and the link to that Italian company. Couldn't find the video of him tinkering in his back yard though. But I found this video, where he presents a very peculiar looking battery, I assume it is a production model. There is no separator at all, and the plates are very far apart and in an unusual configuration.
    https://www.youtube.com/watch?v=SlyeXVmf3gw
    His main invention seems to be that he has found a way to cut down the time of formation from six months to two weeks. Maybe the physical layout of the plates has something to do with it. I assume it is a pure Plante process and not a Faure process.
  • Deveak_Kaizen
    Most likely chemical additives. I don't remember the name of the chemicals. Perch something, but it speeds up the process. The risk is you need to completely wash and clean the plates out or it could lead to further shedding.
  • Deveak_Kaizen
    I've been doing some more research but the one thing i can't get my hands on is empty battery cases! You would swear it was uranium or something. Guess I will stick with glass jars... :(
    I did read that tightly packed plates in pocket separators tend to short less and shed less. The pressure keeps the active material from disconnecting. Not sure if that will work in a plante cell. They tend to expand. Most of the professional built ones basically hang on the sides. You still may be able to have them under pressure but with room below the cell for expansion.
  • BjornM
    I know what you mean. Almost every single component for a DIY battery is hard to find in Sweden. Didn't use to be like that when I was a kid, but now everything is considered dangerous for people or the environment. I have no good source for sulfuric acid yet. Ironically it is one of the cheapest chemical substances in the world. When I lived in Thailand, you could buy it for $2 per gallon.
