Generac 17.5kw broken down
oil pan 4
My 17.5kw generac has been broke down for a while now, the generac repair place doesn' know what to do.
I miss having my generac, it's 922cc 30hp engine and electronic speed control would easily handle loads that beat upother generators and take their lunch money. Loads like a transformer stick welder, big 3.5hp air compressor and my plasma cutter, it can easily run the air and the plasma at the same time.
The problem started when I removed the neutral ground bond to do main panel tie in.
It wouldn't start, because the fuel shutoff solenoid wouldn't open. So I pulled the fuel solenoid armature, then it started and tried to over speed, while not producing any voltage. When it does run at speed it only make 3 volts line to line so it has no excitation.
I restored the neutral ground bond but the damage was already done.
I think it fried the AVR. The electronic speed control needs around 90 to 120v AC to get a signal to speed reference.
I think if I power up the armature while it's running with batteries to create 100v or higher power the speed control should pickup. That would prove the AVR is bad and the speed control is good.
If it is the AVR then I don't want to put another gererac POS on there. For 2 reasons.
One it fried when I broke the neutral ground bond and 2 a new AVR is $160. You are supposed to break the neutral ground bond to to panel tie in.
I would like a different AVR, cheaper, but can make enough field power to get at least 50 amps out of my stator.
If the speed control is fried too I will remake it with a universal speed control and actuator, it will cost a little more than the generac control board, but at least I will be able to get parts for it.
It's kind of hard to think about doing off grid when your big generator is broken. I have a little 7kw it's easy to work on but it's seriously lacking the power of the big one.
  • DanS26
    DanS26 Solar Expert Posts: 266 ✭✭✭
    (Mods...if this is unacceptable advice...just let me know)
    Have you tried the Ziller forum?  Very good bunch of guys over there that know Generacs inside out.
    23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro System monitoring
    Look at Central Georgia Generator   http://centralgagenerator.com/
    They have  video on their home page about ground and neutral.  They also sell many types of AVR's which the antique generator community uses a lot of.
    Also, you "Flash" the windings with a quick DC pulse, while things are static (not running)
    http://www.dieselduck.info/machine/03 electricity/flashing_generator.htm  or
    http://www.davidsonsales.com/FlashGenerator.htm
     I would not use instructions that have the machine running.
    residual magnetism is lost if the generator spins down with a load connected, switch the breakers off, let the engine idle a couple minutes to cool down, then shut it off, without any loads applied
    edited January 2018 #4
    Did you reconnect the neutral to ground bond?
    Some ups (backup inverters) would not auto start if the neutral bond is open.
    Bill
    PS: Any useful information, even off forum, is fine.
  • oil pan 4
    I don't have a loss of residual magnetism since it's over 3 volts, plus one of the features is it has field boost that sends something like 6 volts of battery power through a resistor to the field every time it builds up volts.
    Yes I reconnected the neutral ground bond, but it would appear the damage is already done.
    I worked on big generators in the air force, I flashed a lot of fields because the crew chiefs liked to turn off the generators under load.
  • oil pan 4
    I posted the question on ziller electric, no one responded and then 2 days later they deleted my question.
    Guess I exposured a massive design flaw.
    Now I think I need to do a detailed redesign of their generator. Showing how to rip out the dewply flawed, way over priced OE AVR amd replace it with one that probably isn' any better but is a heck of a lot cheaper.
  • DanS26
    Your post on Ziller was not deleted but moved to the proper forum.....Guardian Portable Gasoline Generators.    And you did get a response:
    http://zillerstore.com/forums/showthread.php?t=4901
  • oil pan 4
    Oh I didn' know it was considered a gardian portable. I didn't get any private message saying it was deleted or moved.
