Trace DR 2424 inverter fix.
littleharbor2littleharbor2 Posts: 817Solar Expert ✭✭✭✭
I recently picked up a Trace DR 2424 inverter. When I removed the housing to access the interior of the inverter I noticed the tiny button that controls the power, on/off function had broken off at its base, which is an equally tiny pot or whatever you would call it.  I'm really surprised to find a Trace product with such a miniscule component controlling a vital function. Sorry I didn't get pictures of it while I had it opened up. If you are looking at the face of the inverter it is the first tiny dot to the right of the square jack on the far left of the controls. I was hoping that someone out there has dealt with this problem and can point me in the right direction. heres a page from the manual which is clearer than my photo,  http://powertool.manualsonline.com/manuals/mfg/xantrex_technology/dr2424.html?p=58
2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
  • 706jim706jim Posts: 185Solar Expert ✭✭✭
    Will the inverter turn on or off if you depress the base of this button with a toothpick or similar?
    If not, there has to be some local place that could replace the contacter.
    If you can live with MSW you will be pleased with the Trace.
    Mine has performed flawlessly for 24 seasons.
    Island cottage solar system with 1400 watts of panels, Trace DR1524 MSW inverter, Trace C40 PWM controller 8 Trojan L16's. My 25th year.
  • littleharbor2littleharbor2 Posts: 817Solar Expert ✭✭✭✭
    Thanks for your reply, 706Jim. I just got off the phone with a very helpful service center and was told that this switch is the common failure point on these inverters. They informed me that these particular switches aren't made any more but the have removed them from units in their Trace boneyard. They don't have one at this time though.
     Funny I thought about using a  toothpick too as you suggested and he said that shaft has an electrical contact on it that electronically activates the switch and that a non conductive item like a toothpick wouldn't work.
    This inverter is for a friend who has a 12 volt version and it should be a direct replacement. We're stepping up her system from 12 volt to 24 volt. Funny, down in Baja there are so many off grid people who have been running 12 volt systems forever, mostly because their Trace inverters are still running strong and they just cant justify switching out their fully functional inverters.
    I'm with you there. I contemplated changing my Trace for a PSW inverter when I got an electric fridge, but it seems to be working well despite the dismal power factor shown on my Killawatt.
  • boBboB Posts: 945Solar Expert ✭✭✭✭
    It's a momentary normally open pushbutton switch I think.  Maybe you could just solder something like this in its place ?  Digikey has quite a few buttons that might work.  This is a picture of a Grayhill series 46 switch.  I thought that Alco might have something similar but there's probably lots that will work OK.
    This inverter is supposed to be a replacement for a friend's Trace 2412 version. I really wanted to keep it looking original. I had another suggestion from a member on a different forum to use a remote power switch intended for this inverter. I have ordered a new remote switch and am hoping this will be the simple way to remedy the problem.
     BTW The button/shaft of this switch is about as thick as a pencil lead and the base is about 1/4" x 1/4", In other words its TINY
    Yes, I remember the switch.... It was sticking up too high and was too easily broken.  BTW, the same exact switch, maybe except for color, was used in the Magnum Energy MS inverters except they were recessed so they didn't break so easily.  At least that lesson was learned.
    boB,  thanks for your suggestions. I will look into this possibility.
    Here is the switch series.  It's an E-switch part.  We use it on one of our products so it is still available evidently.  Just noticed it the other day and thought of you.
    https://www.e-switch.com/system/asset/product_line/data_sheet/185/TL3301.pdf
  • NANOcontrolNANOcontrol Posts: 39Registered Users ✭✭
    AMAZING!!  This sure looks right. At that price and free shipping from China I am thinking typo. I ordered them anyway not expecting much but, for a dollar nine, so what. Good eye NANOcontrol, thanks.
    edited December 2017 #13
    boB and NANocontrol, Thanks for your help here, Two hits in one day, nice. I have gotten the remote switch in the hopes that will work. I have to wait till after New Years Day to head down to Baja and try these. fixes.
    Wait a minute,  These come in all shapes and sizes.  I gave that as an example of the search terms, that they are not expensive or out of production. There are 4, 6  and 8mm versions with different button height. If you were to random order sight unseen I would get this.
    https://www.ebay.com/itm/140x-momentary-tactile-push-button-switch-micro-SMD-SMT-tact-switches-14-typeP-T/182917301023?_trksid=p2485497.m4902.l9144
    The specs given on your original link look to be the correct size. If anything the shaft is possibly too long, though I don't think that would be an issue. If it is wrong I'll order the multi size set. Thanks again.
    I'm about ready to give up on my search for the RC4 or RC8 remote switches. I bought what I thought would be a compatible Xantrex remote switch. It won't work.  Being that it is just a moment switch to activate the power on/off and these phone jack type connectors only have 4 wires would there be a way to replace the modular plug and rearrange the wires to go where they need to go. In other words does anybody know where I may find the correct order of the connections on the inverter. I can easily enough figure which 2 wires are the moment switch wires on the remote but what I would need to know is where they go into the inverter side of the equation
    Update on the inverter fix. Found the first moment switches weren't quite right. I found some with the correct orientation of the solder points but the button was too short. That was an easy correction. I have a friend who worked in the aerospace industry doing fine electronics assembly. She made changing out the switch look easy. Inverter is working great now.
