3 Blades vs 5 Blades
13»
  • bmetbmet Posts: 630Solar Expert ✭✭
    Re: 3 Blades vs 5 Blades
    not even long enough to get your first electric bill
  • lucymarcolucymarco Posts: 1Registered Users, Users Awaiting Email Confirmation
    I'm a middle school student and i'm working on a project about wind turbines my hypothesis was if 3, 6 and 8 blades put on a wind turbine 3 blades will produce the most electricity. but my results show that 6 blades was the best and 3 blades was the worst. I didn't find any reason why?
    now I should write my conclusion that why 6 blades was better the 3 blades and I should give a  reason why? I don't know what to do. do you have any suggestion for me to write in my conclusion?
  • mcgivormcgivor Posts: 2,202Solar Expert ✭✭✭✭✭
    edited December 2017 #64
    There difference between a 3 blade and 6 blade is, the 3 blade can operate at higher speeds before the blades begin entering the wake of the other blades, which is favorable for electrical generation. However a turbine is used for direct power, such as  pumping water, where speed is not as important as torque, more blades such as 6, will be benificial because speed is not a requirement, therefore blade turbulence is less of an issue. See link for more information
    https://www.quora.com/Why-is-3-the-optimal-number-of-blades-on-a-wind-turbine-instead-of-say-5-or-more
    1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery bank
  • BilljustBillBilljustBill Posts: 212Solar Expert ✭✭✭
    It may be that the generator you are using reaches its threshold to begin producing enough "Charging Power" at a lower RPM and doesn't need the speed.  So, the three blade rotor may not grab the low speed air as well as your 6-blade rotor, therefore more low speed wind slips by the 3-blade rotor than spins it.
    Use this link and go asked the maker/seller of various small size wind generators why he sells wind generators that have 3 to 9 blades making up his brands/models of blade rotors.  If you find out, please post back here and tell what/why he sells so many variations of in the number of blades for his Win-Gens.
    https://www.ebay.com/itm/DC-output-Confederate-3-blade-500-watt-12-volt-wind-turbine-turbulent-wind/292049663027?hash=item43ff843433:g:cG4AAOSw2gxYwGRO
    Learn by Doing is a great way to understand and remember how and why things work.... ;>)
    Bill
    Bill
  • bill von novakbill von novak Posts: 783Solar Expert ✭✭✭✭
    im running an Air x now with 5 blades. 5ft dia as against the 3 blade 4feet dia
    it definately is less noisy than when it had 3 blades. the manufacturer of the 5 blade set says its because the "holes " between the blades are smaller.. I have no idea except it makes a lot less noise
    The generator starts making power in much lower winds than when using 3 blades
    its production of power is much greater in high winds,
    it was producing so much power in high winds it bent the 2" dia last 3 ft of pipe. had to add guy wires.
    I suspect all of that is due to the larger diameter of the rotor.  A 5 ft dia rotor will produce 50% more power than a 4 ft dia rotor based purely on swept area - and will tend to rotate more slowly (RPM-wise) to maintain the same tip speed.
13»
