Generator to MPPT
Starmoral
Starmoral Registered Users Posts: 13 ✭✭
I have generator rated 1500W , 24v so I m thinking hooking it directly to 80A MPPT and to 6Kw battery bank. I know it’s been discussed why can and why can’t be done this way,but I wanna know does anyone here actually tried to do something similar? Of course I would like to hear more opinions why this can’t or can work. And what would be best option to implement this generator into my off grid system.
  • 706jim
    706jim Solar Expert Posts: 514 ✭✭✭✭
    So you want to hook a generator to a charge controller?
    I thought they were only compatible with DC current.
    Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
  • Starmoral
    Isn’t that on picture bridge rectifier?
  • Estragon
    What is the nominal voltage of the 6kw bank? 24v?
    Is the output of the generator 24vac? Recified to dc?
  • Starmoral
    Batteries I just ordered they will arrive coming days , but yes that’s the plan, 24.
    I guess it is rectified to dc? Although I can measure ac too on multimeter when I rotate it. What do you think? Here is picture
  • Estragon
    Among other problems, most mppt charge controllers buck higher voltage dc current down to battery charging current. A 24v nominal bank will likely want ~29v absorb charging voltage. An mppt controller would need at least ~ 45v or so.
  • Starmoral
    Well, yes, but with no load voltage goes up to 40V. So what would you suggest for this rating ?
  • Starmoral
    Also is that means that with 12v should work in theory ?
  • Estragon
    I think what you want is a good voltage regulator, not an mppt charge controller. They would be easier to find for 12v, but I think they're available for 24v.
  • Starmoral
    You mean , generator -rectifier- voltage controller - charge controller -battery ?
  • Estragon
    The regulator is instead of the controller.
  • Starmoral
    Point some links&examples. What should be power rating of regulator ?regarding rectifier 30A 1000W I have
  • Estragon
    You could start with www.balmar.net
    They make high output alternators and 24v regulators for them.
  • mcgivor
    edited December 2017 #14
    A generator with a bridge rectifier would be in essence a  DC power supply, the output however would not be a smooth DC such as a PV panel, an electrolytic capacitor would smooth the output, which could be used as an input to a MPPT controller, at least according to Morningstar. My advice would be  to ask the manufacturer of the controller you have, if this is possible with your particular controller. See question 3, using a power supply as a substitute for PV panel in the link below.
    http://support.morningstarcorp.com/faq/
    Edit, the open circuit voltage may be 40V but the load voltage will drop, to charge a 24V nominal battery over 30V would be required, preferably higher, this would be a very Inefficient means of charging by the way, as ~80% of the fuel is wasted as heat, the internal combustion engine is not particularly efficient.
    A generator with only a simple rectifier (4 diode bridge) will have too much Ripple for most charge controllers to manage.
    A MPPT controller expects to see "soft" solar panels, and searches electronically for the MPPT setpoint, and relies on adjusting the PV voltage to control charging.  A generator will never behave like PV panels.
    Some MPPT controllers have preset curves for Hydro or Wind generation, but they also rely on large voltage clippers and loads to help regulate the power, and that would waste fuel on a generator.  Also most turbine gear is multi-phase AC with much less ripple to contend with.
    In short, I don't think you will be happy
  • Starmoral
    edited December 2017 #16
    Thank you, so clearly says on morning star website that MPPT have no issue with this kind of DC. Anyway i would say all of you are talking from theoretical side, no one actually tried to do such thing? So i m gonna try and see ,only way i can know what is going on. Also it is cool idea with electrolytic capacitor as you mentioned ,i will try that too. I let you know everyone how does it go.
    P.S. generator will be powered by pedaling.
    BB. Super Moderators, Administrators Posts: 33,431 admin
    Ok, you are talking about a peddle powered generator/alternator which is probably ~100-200 Watts maximum. A small MPPT charge controller (for example: 15 amps * 14.5 volts charging ~218 Watts) would be more than large enough for your needs (assuming a single person as a power source).
