bulk panel buy
ws9876ws9876 Posts: 327Solar Expert ✭✭✭
I want 4 panels about 260-300 watt. I need .75 a watt. where can I pick these up on the Northern plains ??
  • 706jim706jim Posts: 206Solar Expert ✭✭✭
    DNM solar $245 CDN 330 watts
    Island cottage solar system with 1400 watts of panels, Trace DR1524 MSW inverter, Trace C40 PWM controller 8 Trojan L16's. My 25th year.
  • MichaelKMichaelK Posts: 75Registered Users ✭✭
    For most sellers, "bulk" means a pallet full of 25 panels.  For four panels you'll be paying almost as much for the shipping as you do the panels themselves.
    Here's a company local to me that I've bought panels from.  They have these HanWha panels on sale now.  I haven't actually seen them, but this company tends to market "extra" panels left over from commercial installs.  The ones I bought (LangLi 250W) appear to have been installed, then taken back out of service. I base this conclusion on the fact that some of the MC4 connectors appear to have been used and have bend locking tabs.  But, SB specifically mentioned that they had been returned from a job site.  I did a quicky test wiring single panels straight into a 24V battery string, and tested their output with a clamp meter. Their output was spot on the NOTC documented values.
    https://www.solarblvd.com/products/hanwha-qcells-300w-watt-24-volt-solar-panel/
    If you only order 4 your price point with shipping will be 87 cents per watt.  You have to order 8 of them to get down to 70 cents per watt.
    Can you go into more detail as to your system needs and why you want four 300watt panels?
    15 Renogy 300w panels,  Midnight 200 CC, 8 Trojan L16 batteries, Schneider XW6848 NA inverter, AC-Delco 6000w gen.
  • PhotowhitPhotowhit Posts: 4,606Solar Expert ✭✭✭✭
    Might check with local installers, sometimes they will buy unbroken pallets to get the same or better price and then sell off the extras. Also worth checking Craigslist and Facebook market place, letgo for people selling panels in your area. As noted shipping make for expensive panels.
    Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites,  Midnite E-panel, Prosine 1800 and Exeltech 1100, ForkLift battery. Off grid for @13 of last 14 years. 1000 watts being added to current CC, @2700 watts to be added with an additional CC.
  • ws9876ws9876 Posts: 327Solar Expert ✭✭✭
    i was looking for someone around Salt Lake who might have some. I would consider used ones if they were less than 3 years old and .50 a watt.
