Two inverters?
I have a 300/400 watt inverter. It draws about .40 amps in standby . I just bought a 2000/4600 inverter. It draws over 1.3 amps in standby. The big one will be used for coffee and toast. How many of you run two inverters. The small one runs the tv/entertainment center. And the fridge if needed.
 Thanks in advance
Boondocking is my game
640 Watts Mono Bogart TM2030 and SC2030  Controller GC 6V 208 AH  Costco batteries  300 Watt Inverter and 2000 watt inverter 2 GP 31 192 AH
  • westbranchwestbranch Posts: 5,046Solar Expert ✭✭✭✭
    I have my place wired into 2panels,  the large Inverter will be for the well pump, and washer /dryer when we get them in place... right now the 1500W inverter runs everything else. Idea is to have minimal draw on the batteries in winter
    2 x Cisco WRT54GL i/c DD-WRT Rtr & Bridge, Hughes1100 Sat Modem
  • mcgivormcgivor Posts: 1,903Solar Expert ✭✭✭✭
    Being mobile it makes sense to use a smaller inverter for overnight loads, the self consumption adds up quickly, limited battery and charging real estate are reasons to go that route.
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
  • EstragonEstragon Posts: 2,455Registered Users ✭✭✭✭
    I run a small (300w 12v) PSW inverter at night for lights, radio, etc. It will even run pumps for infloor radiant heating. In daytime I run a pair of 3500w Outbacks in a master/slave stack for water/septic pumps, tools, etc. Coffee is propane stove and french press, but toast is electric now :-)
  • mike95490mike95490 Posts: 7,712Solar Expert ✭✭✭✭
    I don't run 2 inverters, but it was a definite consideration.  Going really crazy, I wonder if I could stack 2 inverters, a 300W and pair it with my XW - which might be adjustable enough for Grid Assist (since it will do generator assist)  I don't know if it will "sleep" enough to be worthwhile.  So I just upsized, rather than deal with potential failures and unhappy wife
  • 706jim706jim Posts: 205Solar Expert ✭✭✭
    I'm still considering this for my summer camp. My "big" inverter (1500 watts) to run everything but the fridge and a 3-600 watt psw for that load alone. So far the fridge has not complained about msw power after two months of continuous operation.
    Island cottage solar system with 1400 watts of panels, Trace DR1524 MSW inverter, Trace C40 PWM controller 8 Trojan L16's. My 25th year.
  • grizzzmangrizzzman Posts: 18Registered Users ✭✭
    Thanks for your thoughts all. I think I will setup two inverters. Looks like it's contactor time.
