Project Issues
KapootaG
Registered Users Posts: 2 ✭
Hi, I'm only an 8th grader working on a project. I have purchased one 30mm 5vdc fan (2 wired) and a 1.5v solar panel module. At the back of the module (not single solar cells, an actual minature solar panel), I have soldered both 2 wires (red into positive and black and negative), after this not working I changed the order on 2 wires (black into positive and red into negative). Both options did not work and i have placed and tilted the model into the sun with no fans working. I am not that smart in these building projects - so I would like to know, is something wrong? the fan is not spinning, do I have to wait for ages? does 1.5v solar panel not work on 5vdc fans? help.
https://imgur.com/a/YLtp2
also, see how there are 2 soldering points - and a green line running to each other, do i have to solder all the metal onto the green line so these 2 points are a metal line (connected)???? -
KapootaG said:Hi, I'm only an 8th grader working on a project. I have purchased one 30mm 5vdc fan (2 wired) and a 1.5v solar panel module.
- 626 Discussion Forums/Café
