Plausibility of 2 gallon electric hot water heater?
2»
  • Desert Rat
    Desert Rat Solar Expert Posts: 138 ✭✭✭
    I'm late to this party, but an option for the electric water heater would be to run it on a separate circuit controlled by the auxiliary relay on your Outback inverter. This would cut power to the circuit whenever battery voltage falls below a set level. I'm doing a similar thing with a mini split air conditioner.
