automate your gas water heater
jeffreyd123
Registered Users Posts: 3 ✭
Gas water heaters can be controlled through home automation devices as well as Smart Phones and computers. A gas water heater timer can save energy and extend the life of your water heater. It is simple to install and cost effective. It can be found on the internet.
What I worry about, now lose hot water if you drop your ac mains unless you have back up power.
I have a 50 gallon electric water heater that costs a fortune to operate. Even though it's "energy efficient" because it's new, it's still costing me about $400 and some change annually to operate for one person. I have been looking everywhere for an intelligent, user-friendly timer that I can control a little easier than with those antiquated gray box mechanical timers. We live in an age of internet and smart phones and I'd like to think that there's a product somewhere that I can use that will allow me to turn my electric water heater on and off as I wish either from my iphone or the internet.Does such a product exist here? Can someone recommend something? Thank you.
A lighting controller such as these https://www.controlbyweb.com/applications/light-control.html could be used to drive a relay or contactor which controls the water heater, one of many available, just a random search result, no affiliation.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
jeffreyd123 said:Gas water heaters can be controlled through home automation devices as well as Smart Phones and computers. A gas water heater timer can save energy and extend the life of your water heater. It is simple to install and cost effective. It can be found on the internet."we go where power lines don't" Sierra Nevada mountain area
