Panel Shade Affect on Entire String
lzhome
lzhome Registered Users Posts: 39 ✭✭
Today at 4pm on October 18th I have about 3 inches of shade across the bottom of two panels horizontally mounted. These two serial connected 12v 100w panels are parallel connect to 2 more panels for a 24v string of 4 panels. This shade will only be present during the winter months.
 Will this shade have negative effects on the other two panels in the string? I will be installing two more strings in the exact same manner, with same shade.
Oops, put this in the wrong category. can't more so hope a Moderator does it for me.
TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter.
    Photowhit Solar Expert Posts: 6,002 ✭✭✭✭✭
    edited October 2017 #2
    Yes, It would be more effective if you can connect the 2 shaded panels in series and 2 sunny panels in series.
    FWIW - I connected mine this way with side by side panels connected and found my early and late day shading comes from the sides, so I should really connect mine up and down...lol.
  • Raj174
    lzhome,
    The power output will be reduced about one third in a string shaded in this way. If it were shaded across the short side, output on the entire string would be near 0.
    Rick
  • mcgivor
    Is the shade a morning or evening event or during peak hours?
  • lzhome
    Morning and peak hours are fine, this is late afternoon as I mentioned 4pm.
  • mcgivor
    Personally I wouldn't worry about it, the critical time is the peak period, production would be so low at 4pm, it would be negligible. Sorry missed the 4pm in your OP.
  • Estragon
    The shadow will move higher and last longer over the next couple of months though. Around here 2pm in a couple of months will look a lot like 4pm now.
  • lzhome
    @Estragon Good point.
    Kinda related but different question. I've only installed two panels as a proof of concept on mounting panels on top of my metal building. I check the panels several times a day for shade and alignment and here in the South the panels are covered with dew in the morning which takes a while to vaporize. Does anyone use Rainx or other types of glass polish to disperse water more effectively?
  • Estragon
    I wouldn't worry about dew. If there isn't enough sun to vaporize it, the panels wouldn't be producing much anyway.
