New Genny
But I really did not buy big enough for any added loads. I am charging through the inverter, and if a load comes on it really bogs the generator down, this cannot be good.
Wondering if I should purchase a 24 volt charger and charge the battery directly with that ? Then any loads that popped up would be isolated from the generator
Anyone doing this?
Off grid, all solar, passive and active (winter wood heat supplements) PV DHW.
Array 1-- 12 Sunpower 250, Outback FM 100 3kw
Array 2-- 12 Sunpower 250, Outback FM 100 3kw
Well array 780w, 6 Kyocera 130 w with Grundfos sqflex 11 and cu200 to elevated storage, ( 2- 330 g tanks,) no battery storage at well
10 24 volt Battle Born Lithiums
Outback Flexpower Two, VFXR 3524A 7kw
Can you not limit the charging current to reduce the load on the generator?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Are you using the choke to start cold? Hondas have a reputation of needing to use the manual coke to start.
Yes of course on choke. And no cannot limit just now as my Mate is not working with the inverter. I think I need to replace one of the boards in the Inverter, but tearing it apart with no back up kinda scares me.
ThanksOff grid, all solar, passive and active (winter wood heat supplements) PV DHW.
The boards on my vfx were pretty straightforward to replace. When I had to replace them though, the inverter didn't work at all.Off-grid.
That's bad news if I understand you. You mean you replaced then it never worked? Or it completely died then you replaced and fixed?
Anyway where did you purchase the boards?Off grid, all solar, passive and active (winter wood heat supplements) PV DHW.
The inverter was completely dead (no LED lights, fan sounds, etc.) when battery power applied. That was why I had to replace the boards. Replacing the boards got it working fine. It sounds like yours is working fine aside from not speaking to the mate.
My boards were replaced under warranty direct from Outback. I found Outback support quite good to deal with. Assuming you've already eliminated cable problems, electrical noise, etc., you might want to contact them.Off-grid.
- 626 Discussion Forums/Café
