Looking to take my 10kw system to 15kw - advice on panels and inverters
WhittakerJ
Solar Expert Posts: 67 ✭✭
Hello everyone, I'm looking to expand my 10kw system to 15kw. I found these Trina TSM-255PA on ebay for only 33 cents per kWh. I'm thinking about buying 20 of them. This seems really cheap, http://www.ebay.com/itm/352174015249 I was thinking about combining them with the Enphase IQ6PLUS-72-2-US micro inverters which are about $150 each,http://www.ebay.com/itm/263209492907
This just seems really inexpensive compared to what I paid in the past and I was hoping someone could comment on this configuration and if there is something I'm missing.
I don't plan on tying this into my existing system except at the service panel. So I don't think it's even relevant. But this is my existing setup. Thanks in advance for your time!
You should check with your utility too. In times past, >10 kWatt systems could have different requirements (different metering/monitoring, different rate plans, possibly even have taxes on excess energy generated). I don't know about Arizona specifically.
> -Bill
Definitely have done this due diligence already. Thanks Bill. Do you have any advice on these panels or inverters? I'm curious as to why the panels are so cheap. -
Trina seems to have good reviews and reputation, that is an excellent price, volume could be the answer.?
http://www.greenworldinvestor.com/2012/09/27/trina-solar-panel-reviews/
Looks like they were installed and then taken down, perhaps fudging for eBay? On their home site they called them used; similar price should get them for near 10% less directly; Between eBay fees and Paypal fees there is almost a 10% cost in selling on eBay.
https://www.solarblvd.com/products/trina-255-w-watt-24v-tsm-pa05-ul-black-frame-poly-60-cell-pv-solar-panel/
