Cheap Chinese inverter reviews?
2»
  • hemmjohemmjo Solar Expert Posts: 88 ✭✭
    Re: Cheap Chinese inverter reviews?
    We are using a KISAE SW1210 1000W, 12V Pure Sine Wave Inverter in an installation at our complex in the Dominican Republic. (http://villagemountainmission.org/) I was worried about it at first from all the comments I saw on here, but it was donated to I had to use it. It has been working fine for almost a year. Our system is totally off grid. We have 4 - 275 watt Solar World Panels, Classic 150 controller and 4 Interstate GC2- 232 ah 6v batteries.
    As it is, the inverter beeps when it goes into surge mode, and the staff knows to dial back their usage, if they don't it shuts down. It does have low voltage shutdown, but I think that is more to save the inverter from damage due to low voltage than the batteries. It only happens when we have a couple of cloudy days in a row, which only happens in Nov, Dec, Jan.
    The system is running a small fridge, small washing machine, 12v LED lighting, small WIFI system, and charges phones and computers. Once in a while we unplug the fridge and run a small drill, grinder or saw. Usually we get the generator our if we need that. The system has been working fine.
    I was planning to upgrade to a 24 volt 2k inverter since most advice I got hear tended to downplay the reliability of the KISAE inverter. But since it is working so well, the only thing an upgrade will do is provide more power so the staff can drain the batteries faster. I do wish it was 24 volt input so the batteries could be wired all in series, but its working well as is.
    John
    Two systems in the Dominican Republic  http://villagemountainmission.org/
    installed Feb 2014 at 19.796189° -70.893594°, Classic 150 + WBJR, KISAE SW1210, MN Battery Monitor, IOTA DLS 55/IQ4,  4- Solar World 275w, 4-6v x 225ah Trace Batteries
    installed Feb 2015 at 19.795733° -70.893372°, same components  as above
    Honda PowerMate PC0497000, 7000/8750w generator - powers the well and chargers maybe once a week
  • jonrjonr Solar Expert Posts: 878 ✭✭✭✭
    Put circuit breakers near the power source. If your wires short together, you will know why this makes a difference.
    I agree about low battery cut off. The issue forced me to create my own.
  • GeraldZengGeraldZeng Registered Users Posts: 1
    CALLD said:
    For me the biggest problem with cheap Chinese products is actually the lack of reliable information and reviews on them rather than inferior quality. When it comes to "pure sine wave" inverters we all know they are traditionally very expensive. But lately the market seems to be flooded with Chinese TSW inverters with price tags that are truly pricing traditional MSW inverters out of the market.
    I for one recently purchased a Ningbo Kosun 24v 2500w TSW inverter for less than $400!
    But what about the potential problems that one may encounter with these "quote me happy" inverters?
    They are so fresh on the market there is no independent feedback available on most of them.
    IMO there are some advantages of going the cheap Chinese route, based on my experience with the Kosun TSW inverter:
    * They could incorporate the latest high-performance technology (even though its cheap)
    * They can be highly efficient due to the use of more solid state digital components and less analogue/mechanical components. Mine for example has no large transformer.
    * Low upfront cost makes purchasing a higher capacity unit is possible giving more freedom to expand and/or lower percentage load on the unit = lower operating temperature.
    Issues I have picked up with mine are as follows:
    * Unstable AC ouput voltage when loads are under 400watts (16% load). The inverter's voltage regulating feedback loop does not switch smoothly under 16% load and creates sharp irregular amplitude pulses on the AC output. The amplitude pulses do however fall within the 10% AC regulation specification in the manual, but due to their frequency and irregularity it can be very annoying when using CFL or LED lighting as it causes them to flicker. The unstable feedback loop also causes high-current pulses on the DC side which register on the kilo-amper scale even when the average current is only in the single digits. You can actauly "feel" these high current pulses in the battery cables due to the magnetic inductance!
    * At loads exceeding 16% the voltage regulating feedback loop stabilises and so does the AC output, however a small amount of high frequency noise is detectable in the AC power but is not an issue for concern.
    Other than these issues I have no other complaints and would recommend this inverter for anyone who needs a TSW inverter on a very tight budget!
    The only thing that remains to be seen is the long term reliability of the unit. It comes with an 18 month factory workmanship and material defects warranty. Mine has been going pretty much 24/7 for the last 4 months. I would however tend to feel that the unstable feedback loop at <16% loads may be putting additional strain on the components although having no experience in this particular field I cannot say that for sure. As such I try to run >16% loads wherever I can.
    If anyone else has experience they would like to share on budget Chinese inverters please post here!
    Regards,
    Sorry for replying the old thread but I think I may answer this question as I used to be a power designer .
    I guess the problem(Unstable AC output voltage when loads are under 400watts ) is that the feedback loop design of the DC-DC boost stage (12V-300?V) is not a good design , you may measure unstable  voltage  on the bus capacitor when it operates at 16% of its full loads  .
    By the way , DC-AC is easier to be stable than DC-DC
    edited October 2016 #35
    Would be interesting to know if the <16% load stability problem also occurs with purely resistive loads.  If not, a line reactor might help.
  • w8qfw8qf Registered Users Posts: 3
    Just to humor myself I have ordered a Power Jack 100a charge controller. I installed 2400w panel system on the roof of the cabin with 4 Rolls L-16's. When the controller arrives I'll offer it 30 days to prove itself but have serious doubts. At any rate I'll offer my experience here around the end of November.
    Dave
    Not sure if this thread is still active.  I have to report that the KISAE SW1210 1000W, 12V Pure Sine Wave Inverter I installed in Feb 2014 has been in continuous operation since then at our complex in the Dominican Republic. http://villagemountainmission.org/
    It stopped working on Monday, so Feb 2014-Aug 2017, it lasted 3 1/2 years. It preformed flawlessly during that time.  Only kicking off when our staff did something crazy, like trying to run a real air compressor, etc.  We have a generator for such things.
    I am going to buy another one for $180.00 to replace it.  That is only 50.00 per year.  I can have a spare on hand at that price.  I wanted to upgrade to 24 volt system when this happened but I cannot go down right now to reconfigure the charge controller.
    What kind of service life are people getting from more costly "name brand" inverters?
  • Marc KurthMarc Kurth Solar Expert Posts: 411 ✭✭✭✭
    edited August 2017 #38
    I have four customers who use the KISAE inverter chargers, all are mobile applications and are the low frequency IC Series models. They have been happy so far. The oldest one that I know of is a 2000 W sine wave unit from March of 2014 and is still running in a full time live-aboard RV application. So just under the age of yours.
    Another is in an industrial truck powering mobile test/measurement equipment in gas fields. That one is about 28 months old running in really severe conditions - 3,000 watts with a 120 amp charger when plugged into shore power.
    Based on this narrow sampling, they seem to make some decent products.
    To answer your other question: I often see 8-10 year old Trace/Xantrex and Magnum Energy inverters still running strong.
    Marc
  • VicVic Solar Expert Posts: 2,827 ✭✭✭✭
    The Xantrex SW +  5548s here are all in their 12th year  --  not an issue with any of they ...   yet.
    As Marc said,   these old SW and SW+  inverters have a very good reputation for ruggedness and longevity.
    There are several Trace SW 4048s at neighbor's properties,   one dates from 1998,   and has been in continuous use since then.
    Another neighbor has a pair of Trace SW 5548s that have been in service since about 2000.
    The one thought about your system,  is that hope that you have as much protection from nearby lightning strikes as possible,   although this is probably not the issue with this inverter failure.
    Thanks for the report.   Vic
  • EstragonEstragon Registered Users Posts: 1,706 ✭✭✭✭
    I had one Outback die at (IIRC) a little over a year old. Outback shipped replacement boards at no charge, and both running fine since. Stuff happens even to the brand names, but at least the support is generally there when it does.
  • MangasMangas Solar Expert Posts: 543 ✭✭✭✭
    edited August 2017 #41
    I had four Xantrex SW 5548 + inverters installed late 2005 which ran 24/7 flawlessly for over 9 years.  Impressive reliability and durability.
    Replaced one inverter board repaired locally in one afternoon.
    Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF House Construction, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers
  • lzhomelzhome Registered Users Posts: 38 ✭✭
    In my search for a 24v pure sine wave converter in the $500 +/- range all I have found is Chinese or Taiwan branded units such as Coteck which is also branded Go Power etc. And too boot these units, or at least the Go Power brand is "not repairable" in case of a failure. So it is a throw-away due to any failure.
    I like Xantrex, had one in my RV for 11 years without failure but they do not support 24v applications in a moderate price range. So the question becomes, is there a quality gap between 12v moderate priced units and upper end 24v units?
    TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter.
  • westbranchwestbranch Solar Expert Posts: 4,905 ✭✭✭✭
    edited October 2017 #43
    I believe the answer is that: there are thousands of 12V units made and hundreds of 24V Units made, supply and demand, plus mass volume production
    2 x Cisco WRT54GL i/c DD-WRT Rtr & Bridge, Hughes1100 Sat Modem
2»
