charging battery bank with an alternator
cockneybob2cockneybob2 Posts: 18Registered Users ✭✭
hi , I have a used small 4 hp  diesel engine and a used 12 volt  60 amp car alternator both work fine , instead of connecting alternator cables straight to the battery bank to charge , is there any reason I can not connect the alternator cables into a totally separate stand alone mppt or pwm charge controller , would this work like a wind turbine and charge the battery bank .
thanks
  • EstragonEstragon Posts: 2,768Registered Users ✭✭✭✭
    I suspect the output voltage would be too low for an mppt controller.
  • cockneybob2cockneybob2 Posts: 18Registered Users ✭✭
    ok , what if I purchased say a 24 volt alternator , would that work in principle
  • mcgivormcgivor Posts: 2,164Solar Expert ✭✭✭✭✭
    Without a voltage regulator, the alternator would probably produce enough voltage to work with  MPPT, with  a regulator it would have too low a voltage and even with a 24V regulated alternator, it would more than likely confuse the tracking of the MPPT, with each trying to take control. You could of course use the regulated 12V alternator without a controller to add current, but it's not the most efficient use of fuel, this includes the theroy with a charge controller, as the battery becomes close to fully charged the more fuel is wasted and this is the reason generators are used as backup, rather than prime charging sources.
    1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery bank
    thanks mcgivor , this charging procedure is only for an  emergency ,  in case all else fails , have seen an economically priced solar and wind turbine charge controller , so guess that's the way to go , not bothered about the efficiency or economics of charging the battery bank as will only use is system once in a blue noon  if at all , as I have most of the gear , I just wondered if it would work , thanks
  • mike95490mike95490 Posts: 7,873Solar Expert ✭✭✭✭
    Not all MPPT controllers are rated to work with a non-solar power source.  They depend on the "source" following solar PV rules, generators & chargers have vastly different impedance response
  • jonrjonr Posts: 1,066Solar Expert ✭✭✭✭
    If the MPPT controller has a higher amp rating than the alternator, it will draw too much (unless the alternator has current limiting or a fuse).  Plus alternators require voltage to start producing power.   I agree - connect the regulated alternator directly to the batteries.
