How can I tell which model generator I have??
murphysplacemurphysplace Posts: 2Registered Users
edited August 2017 in Wind Power Generation #1
Hi, Not sure if this blog is even still open. I got a older Air X wind generator at a yard sale, it needs blades, but I don't know which model it is, the only number is stamped on the end where the pole would go in, and it is: 19560 I don't want to buy the wrong blades for it.
  • mike95490mike95490 Posts: 7,558Solar Expert ✭✭✭✭
    Hopefully, someone knows.   Try writing air-x ?
  • mcgivormcgivor Posts: 1,532Registered Users ✭✭✭✭
    edited August 2017 #3
    Before even considering buying blades, test to make sure it actually works, use a drill to spin it, but then again, since you don't know the model, it would be logical to assume there is no wiring diagram available. Most Air X wind generators seem to be white in color as opposed to the disentery green. The blade bolt spacing may be of help, sorry can't be of assistance, other than that.
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
  • Raj174Raj174 Posts: 578Solar Expert ✭✭✭✭
    The attached PDF file is the spec sheet for an Air-X model that looks a lot like the one you have, though it's white. There is a phone # at the bottom, maybe they can help.
    Rick
    12 x 300W Renogy PV, MNE175DR-TR epanel modified, MN Classic 150, Outback Radian GS4048A, Mate3, 54.4V 207AH HI Power LiFePO4 no BMS, 4000W gen.
