How can I tell which model generator I have??
murphysplace
murphysplace Registered Users Posts: 2
edited August 2017 in Wind Power Generation #1
Hi, Not sure if this blog is even still open. I got a older Air X wind generator at a yard sale, it needs blades, but I don't know which model it is, the only number is stamped on the end where the pole would go in, and it is: 19560 I don't want to buy the wrong blades for it.
    Hopefully, someone knows.   Try writing air-x ?
  • mcgivor
    edited August 2017 #3
    Before even considering buying blades, test to make sure it actually works, use a drill to spin it, but then again, since you don't know the model, it would be logical to assume there is no wiring diagram available. Most Air X wind generators seem to be white in color as opposed to the disentery green. The blade bolt spacing may be of help, sorry can't be of assistance, other than that.
  • Raj174
    The attached PDF file is the spec sheet for an Air-X model that looks a lot like the one you have, though it's white. There is a phone # at the bottom, maybe they can help.
    Rick
