Best way to hook up eight 12 volt batteries for 48 volt system...
2»
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,144 ✭✭✭✭
    At the risk of being overly repetitive:
    If you are concerned about resistance/conductivity, go basic. Measure the voltage drop and current draw on each cable segment with the largest load that you can muster. Isn't that the whole point?
  • Marc Kurth
    edited July 2017 #33
    Everything you want to know about your blue batteries: http://centexbatteries.com/fullriver/OandM.pdf
  • mcgivor
    Dynamic testing with a load, using a DVM set to milli voltage scale, lug terminal, would reveal if there is a volt drop, volt drop would  mean resistance. As @bill von novak stated contact resistance renders them unsuitable for trouble shooting, the ohms per volt of the meter is also a consideration, when tracing ground faults on fire alarm systems, I would use an analog meter as the DVM would read all over the map, insulation testers are useful for that purpose too, with extreme caution.
    The way to measure for bad lugs/crimps/attachments is  fire up the charger in the morning and send 20-40A through the system.  Then you start looking for VOLTAGE.  When you find voltage between 2 points, that's the high resistance point.
    I've used similar technique to find Vcc - Gnd shorts in wire wrap planes, and multi layer PCBs
  • bill von novak
    softdown said:
    Still might be useful for finding a bad connection with the lugs?
    Generally not; it's hard to detect a .1 ohm difference with a meter, even though a .1 ohm increase will result in 250 watts of heat in the connection if you are drawing 50 amps.  (And 250 watts will quickly make the problem worse.)
    If you really need to measure resistances down that low, then get a 4-wire meter.  They are much more accurate.  You can also use two cheapo meters and a lab supply to do the same thing - send 1 amp through the wire via the lab supply and one meter, then use the other meter to measure millivolts on the WIRE ITSELF (i.e. lab supply and second meter connect to different points.)  Then it becomes easy - 1 millivolt on the second meter is 1 milliohm of resistance.
  • softdown
    softdown Solar Expert Posts: 3,819 ✭✭✭✭
    3/4" copper tubing is about the best battery bus bar.
    Just spent 1/2 hour trying to upload the 3/4" copper bus bar battery connections. Having downloaded all Microsoft updates, my laptop now works at a veritable snails pace. Including not recognizing the smartphone that it recognized 15 minutes ago. Oh well.
    Edit: Can you believe the laptop decided to recognize the phone after five minutes? Newer technology = state of the art nirvana!
