Magnum PT-100: Power Status Code P04 - Help Please
lfmgtc59
lfmgtc59 Registered Users Posts: 14 ✭✭
Hi All:
I finally today got my PT-100 up and running and all seems to have gone very smooth.
I do have a question though I hope someone can help me with, or point me in the right direction at least.
Everything looks good, except I am getting a Power Status Code of "P04". The manual gives a couple of sentences explaining this (pg51 / table 4-2), however I'm not really sure what I should be looking for in order to determine the exact nature of the fault and what to do to fix it.
Their one "hint" concerning the possibility of the PV array's VOC to close to battery voltage, does not seem to apply as I have around 37V from the PV array and a 12V battery bank.
Any help you can give would be very appreciated as I cannot find anything online concerning this.
The complete system consists of:
PT-100
MSH3012M
ME-ARC50
ME-BMK
8 Q-Cells Q.PLUS L-G4.2 330 (330W) - run in 8 individual strings to combiner box  (for specs see below)
(2) 800 AH 12V batteries (basically newly refurbished pallet jack batteries) connected w/ 4/0 AWG welding cable.
 Also:
The Remote and PT-100 displays are only showing 0.9 kw for the entire array in full sun 90 deg to panel.  Could this be because of the power limiting caused by the P04 or is something else going on here?
Thank You
Lee
Panel Specs:
DC Electrical Characteristics
  • STC Power Rating 330W
  • PTC Power Rating 305.4W 1
  • STC Power per unit of area 15.4W/ft2 (165.5W/m2)
  • Peak Efficiency 16.55%
  • Power Tolerances 0%/+3%
  • Number of Cells 72
  • Nominal Voltage not applicable
  • Imp 8.91A
  • Vmp 37.02V
  • Isc 9.49A
  • Voc 46.55V
  • NOCT 45°C
  • Temp. Coefficient of Isc 0.04%/K
  • Temp. Coefficient of Power -0.4%/K
  • Temp. Coefficient of Voltage -0.135V/K
  • Series Fuse Rating 15A
  • Maximum System Voltage 1000V
    Hi Lee, I took a look at the manual. I don't use this charge controller but have some back ground. Bill and others likely understand the nature of the problem better than I do, but let me post a photo of the info and ask a couple questions;
    As this has to do with perceived voltage, could you give us the size of your array and the size of your battery bank? Perhaps an undersized battery bank would have a voltage climb inside of the pulse...
  • lfmgtc59
    I appreciate your quick response.. I edited the initial post to include the system specs, excepting the battery bank info; it is as follows:
    (2) 800 AH 12V batteries (basically newly refurbished pallet jack batteries).
    Wire:
    8 AWG  all panels to combiner box
    2/0 AWG (welding cable) from combiner to PT-100
    2/0 AWG pigtail from PT-100 to Breaker & or Stud
    4/0 AWG from Breaker & or Stud to Battery
