Tripp Lite AWS2012SW problems
WolfMT
WolfMT Registered Users Posts: 21 ✭✭
when I start inverter it runs as designed and then I start generator and inverter switches to charging mode
after charging for awhile it switches back to DC mode and will not switch back to AC and charging mode unless I shut the system down for a few hours
anybody have any ideas?
  • Estragon
    My first thought would be that the AC goes out of spec (heavy start current loads?) and gets dropped. Don't know why you would need to shut down for so long though. Does it get hot?
    BB. Super Moderators, Administrators Posts: 33,433 admin
    Some folks have found that they need to put (for example) a 100 watt filament lamp on the output of the genset to "stabilize" the output voltage and current.
    Do you have a meter that can measure frequency (Kill-a-Watt or similar)?
  • WolfMT
    It doesn't get hot, the generator is running rest of house that doesn't go through inverter
  • WolfMT
    I have a multimeter, and generator runs other lights so it has a pull from lights of several hundred watts
  • WolfMT
    Inverter has no issues in DC Mode, runs everything that is wired to it, I have 4 6 volt batteries that are also fed 500 Watts from solar panels, this inverter powers TV, DVD player, Cell phone booster and Phone
    Only issues is charging batteries in AC mode
  • Estragon
    What is the voltage and frequency of the generator AC power at the AC in terminals of the inverter?
    What state are the status lights in?
    Is this a new installation, or did it work as expected for some time and only start doing this recently?
  • mcgivor
    Not sure if this link will address your particular issue but worth a read
    https://blog.tripplite.com/which-type-of-ups-system-works-best-with-a-generator/
  • WolfMT
    voltage is 130, it would be considered a new installation as I replaced a tripplite 1012 with this 2012
  • WolfMT
    thanks
  • WolfMT
    seems I need a 1000 Watt draw off of generator to stabilize voltage so inverter will switch to charge mode
  • jonr
    You could try slowing the generator down a little to reduce the light load voltage (eg, 125V).
