Latest offering from Power Jack (ugh!)
2»
  • mike95490mike95490 Posts: 7,783Solar Expert ✭✭✭✭
    softdown said:
    Everyone agrees that the 60,000 watt claim is likely ludicrous. It is a 24 volt inverter by the way.
    A 750 mcm cable could possibly handle the voltage for several seconds? As memory serves....that cable has almost four times the mass of a 4/0 cable.
    What kind of cable are used on electric chairs? They have to be huge.
    Copper handles Amps
    Insulation handles Voltage
    Electric chairs use voltage, the human body resistance requires more voltage, only takes 10mA to stop the heart
    and from the intertubes:
    "The first execution used a voltage of about 1,700, although it was not officially recorded. The voltage has tended to increase over time and in the modern era the voltage is usually 2,000 to 2,200 volts at seven to twelve amps."
  • mcgivormcgivor Posts: 2,037Solar Expert ✭✭✭✭
    edited December 2016 #33
    So get a step up transformer 1:10 hook it up to this Power Jack and finally there will be a use for it, an electric chair....... because it's doubtful it can do what they claim.
      1500W, 6× Schutten 250W Poly panels , Schneider 150 60 CC, Schneider SW 2524 inverter, 8×T105 GC 24V nominal
  • softdownsoftdown Posts: 1,839Solar Expert ✭✭✭✭
    Doubtful indeed. Yet at ~155 pounds, it is likely to be quite powerful. Copper windings are not cheap.
    Don't forget to look for the bag of sand, hear the Chinese are moving their real estate one bag at a time.
  • littleharbor2littleharbor2 Posts: 979Solar Expert ✭✭✭✭
    At that price I highly doubt the windings are even made of copper.
    2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old  but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
    It was $1000 at Amazon...seems to have disappeared. Don't think I have seen windings that are not copper.
    edited December 2016 #38
    My comment was sarcasm, but you never know.
    Maybe copper clad aluminum.
    This entire thread was meant to be on a sarcastic note, at least from my angle.
    There is a "bag of sand" ballast in orbit right now.  The payload internals changed, and weight was added to keep things balanced per the original plan.  Sand got a free flight into space.  Carefully washed and bagged so as to not outgas anything.
    And I think some clone brand of test equipment installed iron weights in their gear to more closely emulate HP gear in the 80's
    Oh yes, aluminum windings are common.  Usually discovered about 3 years in, as they start to fail at the splices.
  • Dave AngeliniDave Angelini Posts: 3,879Solar Expert ✭✭✭✭
    I still have a special ache in my back from lifting those HP Spec Ans, Sig gens, and Network Anylyzers. :)
    "we go where power lines don't" Sierra Mountains near Mariposa/Yosemite CA
     http://members.sti.net/offgridsolar/
    E-mail [email protected]
    UPS really outdid themselves this time. Appears to have been dropped about two feet. Look at the large bolt head at the bottom of the unit. Some of the racking busted loose. Weighs 102 pounds instead of 150. The coil is wrapped.....could indeed be aluminum instead of copper for weight and dollar savings.
    Seemed decent enough until UPS got a hold of it. Electronics are often not built to be dropped. The handling was so severe that I wonder if the government got a hold of it.
    Yes....I gambled on it for a few reasons.
2»
