Buying a used solar panel ?
bc buck
Registered Users Posts: 59 ✭✭
Talked to a guy wanting to sell a Sharp 235w panel for a $100. What should I look for other than cracks in glass and voltage output.
If I were to consider a used panel these are the things I would check, open circuit voltage and short circuit current and determine if there's a use for it, for example if it a 60 cell panel, it cannot be used with a PWM controller. The glass won't crack, it will only turn to cubes if broken, my opinion would be to consider new panels over used, you might be able to get close to that price with new, sometimes buying used is a false economy.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Damage to the back sheet. Any discoloration in the cells and cell interconnect tabbing. Most solar panels (including Sharp) use tempered glass and when broken will shatter into a "million pieces" so if not shattered the glass should be fine.
Voltage output isn't a full indication of a working panel. You want to see the short circuit amperage and is so equipped test the panel under load.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
bc buck said:Talked to a guy wanting to sell a Sharp 235w panel for a $100. What should I look for other than cracks in glass and voltage output.
I think you had some Kyrocera 12 volt panels? This would not be compatible with those.
Not really a great price, other than you don't have to worry about shipping. We're seeing prices for new in this neighborhood.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Photowhit said:bc buck said:Talked to a guy wanting to sell a Sharp 235w panel for a $100. What should I look for other than cracks in glass and voltage output.
Not really a great price, other than you don't have to worry about shipping. We're seeing prices for new in this neighborhood. -
bc buck said:Yes, I installed three Kyocera KD145sx-ufs in series. When I replaced my battery bank I increased the AH to 430. Could use a little more watts if I could get a good deal and save on shipping. The Morningstar PS-MPPT-40 said it could be over watt in panels as long as did not go over Voc of 120 DC. The three Kyrocera total Voc=66.9. Was thinking if added Sharp in series 37 Voc would = total Voc of 103.9. Does this sound like it would work. Thanks
Photowhit said:bc buck said:Yes, I installed three Kyocera KD145sx-ufs in series. When I replaced my battery bank I increased the AH to 430. Could use a little more watts if I could get a good deal and save on shipping. The Morningstar PS-MPPT-40 said it could be over watt in panels as long as did not go over Voc of 120 DC. The three Kyrocera total Voc=66.9. Was thinking if added Sharp in series 37 Voc would = total Voc of 103.9. Does this sound like it would work. Thanks
- 626 Discussion Forums/Café
