Have Lithium Ion batteries come of age for off-grid systems?
karrak said:jimmyaz said:With the LFP nowadays..... Which supplier is the trusted one? Or do they even know what they are selling is quality battery or just another cheaply made one. I'm not trying to be sarcastic, I am asking if I were to buy LFP, where would I buy it from if I am in North America?
Simon
Is your system 8cells of 3.2v to make up to 24v system? So if I want 48V then best option is 16s? Am I right that all of these LFP on the market are made in China?
South Korea is where mine are made."we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:South Korea is where mine are made.
I know,. nowadays it's hard to find real quality stuff unless you got deep pocket. I guess there's always risk in everything. But I used to sell LiPo and deal with many Chinese supplier.... so I know what their quality is and there's no such thing as Quality Check.
That is suppose to answer your question that not everything is made is China!"we go where power lines don't" Sierra Nevada mountain area
Dave Angelini said:That is suppose to answer your question that not everything is made is China!
karrak said:Voltronix http://voltronixusa.com/products/ is selling the Winston batteries under their name in the US, these are the batteries I use.
Simon
Simon, those appear to be LYP batteries not LFP
jimmyaz said:Is your system 8cells of 3.2v to make up to 24v system? So if I want 48V then best option is 16s? Am I right that all of these LFP on the market are made in China?
What are you thinking of using the battery for?
Simon
Off-Grid with LFP (LiFePO4) battery, battery Installed April 2013
32x90Ah Winston cells 2p16s (48V), MPP Solar PIP5048MS 5kW Inverter/80A MPPT controller/60A charger, 1900W of Solar Panels
modified BMS based on TI bq769x0 cell monitors.
Homemade overall system monitoring and power management https://github.com/simat/BatteryMonitor
westbranch said:Simon, those appear to be LYP batteries not LFP
Simon
karrak said:jimmyaz said:Is your system 8cells of 3.2v to make up to 24v system? So if I want 48V then best option is 16s? Am I right that all of these LFP on the market are made in China?
Simon
Simon, I think they are maybe fine for an advanced user like you but totally disagree that one would want anything short of the best offgrid. We are a small group living successfully offgrid. The transition from abundant power to lights out is something we just cant have and safety is right up there!"we go where power lines don't" Sierra Nevada mountain area
Simon
Currently my setup is completely independent and not tie to the grid. But I have decided to install a Hybrid Inverter so I can run more load through out my house and the concept is to "Self Consumption and NOT feeding grid" all solar produce and maybe a small amount of battery usage during heavy load. Obviously do not want to constantly use the battery, but I want to be able to use some so that when solar is over producing, it can store into the battery and turn around I will used it when needed.
During winter time here in Arizona, my entire home only uses 11-15kw a day and during Summer time, 50-80kw a day. My current array is 2.6kw. Usable sun here in Winter = 5-6hours, Summer =7-8hours. So I want to be able to offset as much as possible.
There may be a problem, because all Hybrid Inverter running in AC support mode would require to pull the first 500watts from the Grid before it invert DC. Everything in my house is super efficient therefor most of the time all the small load only pull 300-400 watts. So it will not go over that threshold.
Simon, I am waiting for more info to come back from them, but here is what he had to say so far
We have the LYP which is very similar to the LFP. .... What is your application?
Brennan Patrick Beach
CEO
Voltronix® USA, Inc.
@ westbranch,
LYP is a LFP cell that has the rare earth element yttrium added at the cathode to enhance charge and discharge of the battery at much lower temperatures. The specs indicate -45C.
This is from an EV forum.
Re: whats the difference between lifepo4 and lifeypo4Hello Subevo,
the main difference between lifepo4 and lifeypo4 is additional Yttrium at the cathode of the lifeypo4 cells to speed up electron transfer especially at cold temperatures. They are the better choice, especially for electric car usage. I received my cells in spring of last year, my car was one of the first conversions done with Yttrium cells. While driving through the whole last winter here in Germany I´m very surprised of these cells providing high amps at cold, freezing temperatures. I was able to drive my car at the coldest days. Without Yttrium this should not be possible regarding the experience of others. The voltage sag under freezing point is too much with the old cells. Yttriums sag a little bit, but you´re able to drive and receive the whole stored energy. Believe me, they´re really good.
This is a link to the Winston battery specs. Notice the low charge and discharge temp and also extended life cycle.
http://en.winston-battery.com/index.php/products/power-battery/item/wb-lyp200ahab?category_id=176
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Dave Angelini said:I think they are maybe fine for an advanced user like you but totally disagree that one would want anything short of the best offgrid. We are a small group living successfully offgrid. The transition from abundant power to lights out is something we just cant have and safety is right up there!
There are well over ten DIY off-grid systems that I am aware of that use the cheaper Chinese prismatic batteries and not one has stopped working due to a battery failure.
I totally agree that safety is a paramount consideration. IMO a simple off-grid system that is properly designed with a BMS of some sort that is being monitored and serviced on a regular basis by someone that understands the system could be safer than some complex branded "black box" which might have some engineering defects/shortcomings in it or might have been installed incorrectly or both. I suppose with the black box at least you have someone to sue if something does go wrong.
Simon
Simon
karrak said:Dave Angelini said:I think they are maybe fine for an advanced user like you but totally disagree that one would want anything short of the best offgrid. We are a small group living successfully offgrid. The transition from abundant power to lights out is something we just cant have and safety is right up there!
Simon
Power is just power and there are many ways to make it happen. We go where the power lines don't!
We agree on that part!
Less is more is great also up to a point where the inverter power bridge shorts, a charge controller goes into runaway or a BMS defect . All of these devices need to be watched and not because of a law suit, in systems I am involved with. It is a heart beat to me.
My choice right?"we go where power lines don't" Sierra Nevada mountain area
- 626 Discussion Forums/Café
