trace c30a
icarus
Solar Expert Posts: 5,436 ✭✭✭✭
This is perhaps not the right way to post this, apologies in advance.
Does anyone have a copy of the owners manual for a Trace C30A charge controller that they could post or e-mail me? One just fell into my lap so I would like to know about it.
Xantrex hs not gotten back to me on availability.
Thanks.
Icarus
Thanks.
Icarus
Re: trace c30a
Many of the C series manuals are here:
http://www.xantrex.com/web/id/72/p/docs/pt/25/product.asp
(found by
Charge Controllers (lower Right side)
C Series Charge Controller
Document DownloadsPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: trace c30a
Unfortunalty they don't go back to the Trace C30 series.
Icarus -
Re: trace c30a
The C30A was an old relay type controller that was discontinued by Xantrex/Trace about 5 years ago. -
Re: trace c30a
Right you are,,Any idea how to find a manual?
PS: Jim, I went to your link and BINGO, there it is,,, I don't know why I didn't find it when I looked!
Once again thanks for the help and thanks naws for the forum!
Icarus -
Re: trace c30a
Manual or not, I don't recommend using it - they are not very good (never were, even 20 years ago, but not much else available then). -
Re: trace c30a
It came with a bunch of other stuff. I was gonna e-bay it, to get it off my bench! Any takers?
Icarus
- 626 Discussion Forums/Café
